Do All Engine Mods Require a Tune?
In particular on the LS3 engine, it seems that the engine's balance is delicate enough that when you mess with its air intake and exhausting capabilities you may actually be robbing the engine of performance (at least in some rpm range(s)) as it attempts to compensate for measured changes in air/fuel mixture or pressure. In this sense, it's not a matter of tuning to "get the most out of the modification" (even though with the tune and the mod you may add net horespower or torque), but more a matter of ensuring the mod is not costing you power. Am I understanding this correctly? Or have I fallen prey to tuner marketing wives tales?
but what i can tell you is that besides your points, there are hundreds of codes that will/can be thrown when outside of allowed limits. tuning keeps you out of 'limp mode' at a minimum due to a cel thrown and out of unsafe limits that could harm the engine.
anyway, thats my point
Thank you. I believe I've found a performance product vendor who also does tuning. It seems as though this particular vendor's product does not require tuning and to the extent tuning is done as an option, it is done to keep the engine running properly. In other words, in addition to the 15 rwhp gain from the product, the vendor won't be tuning in such a way as to try to deliver an additional 20+ hp while subsequently voiding my warranty. Not ready to go there yet.
Thanks Again!
Adding any simple mod like an air filter or CAT back mufflers, your PCM will NORMALY easily be able to adjust the fuel trims and allow the engine to run without issues.
When you start adding mods like a CAM, intake manifold (FAST 90/92/102 or headers; you significantly change the air flow thru the engine and the PCM has a tougher time adjusting to run correctly.
The PCM adjust a table called Long Term Fuel Trims (LTFTs) to correct for the AIR FUEL RATIO changes. The PCM can only adjust +- 25% and some mods will max out that table in the RICH direction.
That will cause the Wide Open Throttle Air Fuel Ratios in the Power Enrichment (PE) table to be significantly rich and performance will not be optimum when the AFRs are too rich.
Bottom line.. Any mod that DOESNT need tuning will not increase the engine performance all that much.
You can look at it like this to make it really simple. If it is in front of the MAF, or after the 02 sensor you can change it and it wouldn't need a tune.
Anything between the MAF and front 02's will probably require some sort of tuning change to get the most from that modification.
Thank you kindly. Your responses are straight forward and to the point and worded such that even I can understand. This is most helpful and will influence my purchase decisions going forward.
Thanks again!
Sincerely,
Rathmullan
