Can I get some opinions on what the best cold air intake system for my 2009 C6 Coupe is?
Everybody always wants the best, but if there truly was a best, only one would exist and it would be a moot question.
BTW, I use a Vararam because I wanted maximum performance. I use it with a Donaldson filter available through Amsoil because I wanted excellent filtration too.
I have a 3 week old SLP Blackwing kit for a LS3 for sale. I had to remove it when I installed a E-Force supercharger. This kit flows 99% more air than stock.
Besides more does not mean better, it just means it is not a restriction. However it can also cause other bad issues like turbulence.
I am partial to ours, but ours is the Mamba and if I had to pick one besides mine it would be Jim Hall's from Halltech.
Yes, 700 cfm stock vs 1400 cfm flow thru the SLP intake
So you're saying the power efficiency of a LS7 drops off dramatically after 5600 RPM, due to no longer having the ability to ingest more air? Kinda makes you wonder, doesn't it?
Who flow tested that, besides SLP? And is that stock or aftermarket filter?
Ha. All I know is I had a blackwing and it was the sh!tiest design ever. The lip on the bellows was too narrow and it wouldn't stay on the throttle body. 20 miles and it would slip off and the car would start throwing codes and idling like ***. Went Halltech and never looked back.
