I am contemplating future mods. I want a street car (on coilovers) that has as much hp as possible,that is still able to maintain traction running a good set of performance/track tires. Not drag radial.....as the purpose of this car is all out performance,NOT DRAG RACING....possible hpde in the future. So my question is...what is realistic hp level at which the car will still hook fairly well and not just burn the tires off...?
It doesn't matter if you have 800 or 400 HP with the best or worst tire available if you don't know how to manipulate the clutch and throttle.
I certainly know how to drive a sports car.....I was looking for expirienced opinions on what hp makes a well balanced/usable powered street car. Dont care about 800 hp that you can only use at 100mph+....im talking a nasty 0-100 mph street car
I think 420 to 450 rwhp michelin ps2 is a good combo fo the street
If your interest is 0-100 then it is a drag car and it won't take much over 400 at the wheel to lose traction on the street without DR's.
Depends on the tire. On Hoosier R6 (345x19) I could go wide open in second gear with 600 rwhp and 3.73 rear gear. Same size pilot sport would spin in third and break fourth loose in cool weather with 3.42 rear gear.
I reckon i make 420 ish rwhp and with hankooks i can unstick in 1st and 2nd at will. I reckon if it's 0-100 (and back to 0?) you want tires will give you most bang for buck.
If it's hpde and driveability (confidence) i'd suggest changing out the poor standard suspension.
If it's bragging rights in the boozer then put a super charger on it!
I have joc stage 1, headers, hi flows, fast, killer bee and i think if i added any more power i'd need to be a much better driver!
500rwhp is manageable while 600rwhp things start to get interesting fast.
I'm over 600 RWHP (Corrected) at 5700 ft and even with drag radials it is a lot to handle on the street.
I had PS2 run flats (Forget those at 600rwhp) and I also have a set of Pilot sport Cup tires, they only hold the power on a track when the tire temperature is way up there, not easy to reach those temps on the street driving normally.
i have just over 400 to the rear tires...with kumho's escta's...its pretty slippery when cold less than 60 degrees out........
if i bogged it...i got grip, but pretty slow in the 1/4 mi
Originally Posted by Alvin@PCMofNC
Agreed!
500rwhp and you can stick on the street with a GOOD street tire (not nitto invo's or some similar bullcrap).
I'm at 550rwhp and can hammer on it pretty hard at 40mph with 345/30/19 Khumo XS
You definitely won't be doing any max 0 - xxx runs though on the street on a street tire. Definitely need an R compound for ANY type of low-speed acceleration.
i am simply at full bolt on now w/ fast 102 and ported tb,on coilovers....it hooks well with my kuhmo xs tires. would love to boost to around 550 rwhp if It can be usable power (all this 650-1000hp) is silly,unless you are doing the texas mile or possibly drag racing,imho....ive seen many 500 hp cars take down some 600+ hp cars in a real world situation due to traction....im not interested in doing a smoke show at every press of the throttle.
Well like I said, I'm at 550rwhp right now and at 40mph I can roll into WOT without spinning my 345 Khumo XS.
500rwhp seems like it would be a really good # for these tires. I still feel like I would benefit from the 345 NT05Rs, but I don't want to give up cornering.
I'm just shy of 700 to the wheels and on MT DR's. Its a hand full, especially from 30 or 40.
On the stock tires? Forget it. I kept them on for a minute just to see what it was like. It wasn't even fun.
