Brake rotor surface condition with HP+ pads
http://www.hawkpadsdirect.com/Hawk-P...-Pads-s/13.htm
You can see that the HP+ is listed under "Street Pads" on the left of the page.
I know it says it's a compound "that can take the heat of the track and get you home safely". Autocross, yeah it's OK, but for a heavy car like our Vettes, it's just not a pad for track use on a roadcourse where you're running 25-30 minute sessions.
You really need a track pad for doing serious HPDE or open track day events.
There's no such thing as a dual-purpose street/track pad.
What you're seeing on the rotor is no problem at all, it's actually what you should get when you properly bed pads - a layer of pad material transferred onto the rotor to give you good adhesive braking.
However, with the layer kind of spotty, I think you're probably overheating the pads and getting those spots rather than a nice smooth grayish/bluish tint to the rotor.
For the track I run Hawk DTC70 front and DTC60 rear, or Carbotech XP12 front and XP10 rear with great results. After a track event you'll need to switch back to a street pad.
The Carbotechs are very good because you can swap from their street to track pads without rebedding due to the similar makeup of the compounds.
Bob
Adam
216-780-8825
