2012 G/S Vibration
Old Apr 9, 2013 | 11:03 AM
ohfiver's Avatar
ohfiver
Default 2012 G/S Vibration
4,300 miles G/S auto. Slight vibration only when slowing down (without applying brakes) from speeds over 50 mph, anyone have a similar problem?
Old Apr 9, 2013 | 01:08 PM
LEAVINU's Avatar
LEAVINU
Most common vibration seems to be at hwy speeds due to crappy OEM GY tires.
Old Apr 9, 2013 | 01:45 PM
All2Easy's Avatar
All2Easy
Are your tires "cupping" anywhere on the tread?
Old Apr 9, 2013 | 04:08 PM
ohfiver's Avatar
ohfiver
No cuping, this only happens when slowing down, if it was tires wouldn't it happen on accelaration and deceleration?
Old Apr 9, 2013 | 04:31 PM
LEAVINU's Avatar
LEAVINU
Your problem does not sound tire related. I was simply stating this does not seem like the "normal vibration thread". Sorry I cant be of more help.
Old Apr 9, 2013 | 04:48 PM
All2Easy's Avatar
All2Easy
My theory was that cupping would create ridges that are somewhat "uni-directional." When slowing down without braking, these ridges would be more in play with the tire bringing the car down in speed rather than accelerating or maintaining a constaint speed.
A wild *** guess on my part!
When I have experinced cupping on my motorcycle tires, I pick up more noise and a slight vibration in corners. Hence, my theory on car tires.
Good luck with finding the root cause!
Old Apr 9, 2013 | 07:15 PM
ohfiver's Avatar
ohfiver
Hey thanks guys for the suggestions, just trying to figure this out!
Old Apr 9, 2013 | 08:14 PM
JCtx's Avatar
JCtx
Did you start noticing it all of a sudden, or after hitting a large pothole or something? Or did you let somebody drive your car, like a valet, etc? Anyway, if all your lugnuts are torqued properly, and your tires are inflated properly and not unevenly worn, and doesn't happen when braking, it has to be suspension/steering related. Could be the alignment, a bad bushing, a loose nut, etc. You'll need somebody who knows what he's doing to drive the car and diagnose the issue. Doesn't sound like a big deal, but the hard part is to find out what exactly is causing it. Good luck.
Old Apr 9, 2013 | 11:24 PM
Rathmullan's Avatar
Rathmullan
What happens when you do apply light braking? Does it get more pronounced or does the vibration lessen? If it lessens that would signal more of a tire only issue (check tread, sidewalls and pressure). If it gets worse, that could point to more of a wheel or alignment type issue.
Old Apr 10, 2013 | 12:07 AM
ohfiver's Avatar
ohfiver
I should have mentioned the vibration only happens for a second or two
Old Mar 1, 2023 | 07:01 PM
bvezina's Avatar
bvezina
Cruising
I get a vibration acelerating/crusing starting at about 55-60 then stops. It is not a steady vibration as it happens as almost a cycle? Then back at around 80....
Old Mar 2, 2023 | 10:02 AM
vetteish's Avatar
vetteish
Wheel weight fall off? I have this at a specific speed before in other vehicles
Old Mar 2, 2023 | 03:30 PM
bvezina's Avatar
bvezina
Cruising
Thanks ok so you are saying a wheel weight has fallen off?
Old Mar 3, 2023 | 11:22 AM
vetteish's Avatar
vetteish
I my experience, that was my culprit…I had the wheels road force balanced using a hunter machine and all was well. I know there could be a multitude of things, but could be a good place to start. Idk how old your tires are or mileage
Old Mar 3, 2023 | 12:34 PM
bvezina's Avatar
bvezina
Cruising
The tires are 8 years 15K car has 20K. going to get balancing today...
Thanks for your help....
Old Mar 3, 2023 | 01:14 PM
vetteish's Avatar
vetteish
No problem. Hope that’s it. Also, your tires are getting close to being very old…could play into it. I had that issue as well when I bought mine…tires were ‘new’ but date code was 10 years old
Old Mar 3, 2023 | 04:45 PM
bvezina's Avatar
bvezina
Cruising
Hey there BINGO they were out of balance. I took it to my usual tire shop they pulled all the weights off and re-balanced all 4 $20 the most inexpensive car fix ever!!!
Thanks again for your help and advice..
Bob V.
Old Mar 3, 2023 | 10:22 PM
vetteish's Avatar
vetteish
Bob V.
great news!! Happy I could help. And damn that was cheap…..
To 2012 G/S Vibration
