Cruise control problem
Old May 29, 2013 | 07:20 PM
YLWY2K's Avatar
YLWY2K
Default Cruise control problem
My cruise control stopped working on my '05 M6 coupe. I've tried the toe under the brake and battery disconnect but neither worked. Any repair suggestions other than taking apart my steering wheel, air bag etc. and installing a new cruise control switch. Also, my rpm's stay high between shifts unless I wait 2-3 seconds and then they will return to normal idle rpm. Any suggestions will be appreciated.
Old May 29, 2013 | 07:29 PM
RicK T's Avatar
RicK T
Originally Posted by YLWY2K
My cruise control stopped working on my '05 M6 coupe. I've tried the toe under the brake Any suggestions will be appreciated.
I don't know if you actually meant "brake" or really meant "clutch pedal". On manual trans cars it's the clutch pedal that has the switch for cruise.
If you actually did the brake pedal you might want to try again but hold the clutch pedal up. Check this:
http://forums.corvetteforum.com/1576031710-post6.html
And if you can, scan for trouble codes.
Old May 29, 2013 | 08:36 PM
VET4LES's Avatar
VET4LES
It can be as simple as a stop light not working. Anything that will cancel the cruise control (stepping on the brakes) that is not working properly can cause the cruise control to not work.
Old Jun 3, 2013 | 07:49 PM
YLWY2K's Avatar
YLWY2K
Thanks much for the info. Sorry for the slow reply; been gone for a few days. Will try these fixes and hopefully cure the problem.
Old Jun 3, 2013 | 08:47 PM
Bill Dearborn's Avatar
Bill Dearborn
Check the 2 A fuse in the under dash fuse center in the BCM. It is marked Cruise SW.
Bill
To Cruise control problem
