new track times, something missing?
Old Jun 12, 2013 | 03:46 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by pit-man
I didn't see a Kennedale Dragstrip in the lists. Maybe there was a name change ? Need to find this dragway-speedway to check the DA that day against Northstar.
Looks like Northstar was around +2930 DA
I think I found it as Texas 1/8 mile raceway.
DA was around +2250.
So after adding 100 hp, you had a worse sixty foot time and terrible air. That would be 1-2 mph right there.
A 700 change in DA is about .1 and 1 mph on my car.
But 2900 DA is high, period.
Hulk you cannot compare your 92 mph to any of the record runs. All the fast record runs were done in negative DA.
My manual car will run about 94-95 or so in that DA, but I have to shift 3 times in the 1/8 and as a manual car I'm not that comparable.
I have to say 92 seems low even for that DA.
I think the next step is to find someone with HP Tuners and scan your runs and post up. You might be getting a lot of knock or something.
If you really want to solve the problem, get a wideband and HP Tuners yourself and scan the runs with a wide band reading. That's how you really diagnose problems and fine tune your tune. Made a huge difference for me. Of course as a manual car, I also learned to drive better watching the scans, but a scan is invaluable analyzing track results.
Old Jun 12, 2013 | 05:38 PM
thehulk's Avatar
thehulk
I have the scan tool for efi live that I bought from patg, ill use that
I misplaced my 7.47 1/8th mile run. But found this one fron northstar.
Old Jun 12, 2013 | 05:39 PM
thehulk's Avatar
thehulk
http://forums.corvetteforum.com/memb...ip-145838.html
There's time slip
Old Jun 12, 2013 | 08:48 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
That will do it. Post up a scan. I don't have EFI live but others do and will help.
Old Jun 12, 2013 | 10:35 PM
thehulk's Avatar
thehulk
This may sound silly but I don't I know how to post a scan or log if I use the efi live thing.
Old Jun 28, 2013 | 12:51 PM
PRE-Z06's Avatar
PRE-Z06
According to this thread you ran your stock time back in March...
http://forums.corvetteforum.com/c6-t...-8th-time.html
what was the DA then?
The gains at beast would be 10mph in the 1/4 given the same DA...which equates to 6mph in the 1/8 from the extra 100hp, but a 2000' DA difference could easily take away 2-3mph as Joe G mentioned. Dyno numbers are corrected, track numbers are not
