Clutch Pedal - Need some help.
Old Jul 15, 2013 | 07:48 PM
C6C3Vettes's Avatar
C6C3Vettes
Default Clutch Pedal - Need some help.
Over the weekend I was at a low speed autocross event and when I pushed in the clutch pedal to shift it stayed on the floor and would not come up. I checked the fluid level and it was fine. Another Corvette owner at the event told to manually "pump" the clutch pedal, but that didn't help. The car is a 2013 Grand Sport M6 w/ 1600 miles. I trailered the car to the local dealer from whom I purchased it. They said the clutch fluid was contaminated and probably damaged any part in the clutch assembly that has any rubber or plastic.
Has anyone heard of this happen before?
I had not opened the cap on the clutch pedal reservoir until this happened. Any possibility other than bad fluid from the factory?
THANKS
Old Jul 16, 2013 | 08:54 AM
truckplay's Avatar
truckplay
since you are under warranty it won't cost you to find out. clutch fluid on a new car turn brown QUICKLY from the reaction with the rubber parts. after a few times of changing it, the fluid will remain cleaner longer. hopefully the dealer will change both the slave & master cylinders.
good luck
Old Jul 16, 2013 | 12:35 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hey C6C3Vettes,
Keep me posted on your dealer visit. If there is anything I can do let me know!
Kelly J.
Chevrolet Customer Care
Old Jul 16, 2013 | 07:33 PM
PRE-Z06's Avatar
PRE-Z06
Would the pedal not return if you pulled it up? It's common with an organic clutch and the design of the factory slave for clutch dust to get past the seals and contaminate the fluid. When driven aggressively you have to maintain the fluid by using the Ranger method, see the sticky at the top of the forum for details.
Old Jul 16, 2013 | 07:41 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You all might like this thread.
http://forums.corvetteforum.com/c5-t...cs-inside.html
Originally Posted by chuckster
After tons of speculation on Slave and how much fluid it contains and does it leach black from the rubber...
I have taken my old slave apart to prove once and for all the Slave contains VERY little fluid at all and does leach black from the rubber.
Ok here is a shot of the full slave.
Here is the Slave disassembled without the throwout bearing but just the Plastic plunger that rests on top of the thick rubber piston that the fluid pushes on. The inside edge of the plastic piston is all that makes contact with the rubber piston in the picture below.
Understand that this setup is the reverse of what one would expect. A hard aluminum piston with a rubber seal around it. In this case the piston IS the rubber seal. Here is the seal pulled up
Here is proof that the black leaching is from the piston.
Here a shot of the size of the hole that the fluid enters. Its the same on both sides and it opens to a small channel under the rubber piston
Here is a pice of wire showing the entry point of the fluid.
Now for the question, how much fluid does the slave hold? EXACTLY 2 TABLESPOONS. Yes I used wifeys cooking measuring spoon.
I filled the whole thing up with water and plugged the holes.
I poured it out into a plastic dixie cup..to further demonstrate how little there is.
There you have it.. There is no more magic in the slave...the curtain has been pulled aside...
Old Jul 16, 2013 | 08:17 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
If there are no signs of fluid under your car then I would say its a faulty master cylinder.
Old Jul 17, 2013 | 02:12 PM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by Joe_G
Something else that I don't think was mentioned being that was a C5 slave and GM did add a rubber sleeve to the new C6 slave to try and keep the fluid cleaner which I think helps, but only to a certain extent. Something I've noticed from my experience of running 10 different clutches and 5 different kinds of friction is my fluid hardly ever discolors running a different compound friction material other than stock organic disc that dusts the most.
Old Jul 17, 2013 | 02:23 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My fluid hardly ever gets anything in it even after months of daily driving.
I think my thought below typed 6 years years ago is valid...Chris what do you think about this?
I know from personal experience that fresh fluid fixes this. No question about it. And it only seems to happen after a hard launch with some clutch slippage and attendant heat, or after a high rpm run on a high HP car with perhaps a marginal clamping force clutch that is slipping imperceptably to the driver but none the less is slipping and causing the heat.
But it just seems odd to me that boiling the fluid causes the opposite of what happens when you boil the brake fluid - boil brake fluid, foot to the floor like air in the lines and no brakes. The pedal comes up...but now that I think of it, a bit slowly. Boil clutch fluid, you'd expect to not be able to disengage the clutch... but you can disengage it, the pedal just doesn't come up after you do so! I'm not an engineer so maybe I'm just an idiot on this. But doesn't that seem odd to you too?
I suppose....thinking while typing here.... that perhaps the PP diaphragm on a high rpm shift DOES push back on the slave, as designed (this makes sense as the clutch is fully engaged when this happens, and not slipping, so the clutch is indeed engaged properly - this contradicts the overcentering theory, which would result in the clutch slipping which it does not when this happens), and the slave, with boiled fluid, compresses the air bubbles instead of moving the fluid back to master as designed. And thus the pedal does not come up. After you physically use your foot to transfer the fluid by pulling up the clutch pedal, it works properly again. I'm sure the cr&p in the fluid trying to pass through that tiny orifice Chuck shows above doesn't help any in the fluid transfer so fresh fluid would help there also.
Old Jul 17, 2013 | 04:34 PM
PRE-Z06's Avatar
PRE-Z06
That's because you don't have any material left on the disc Joe lol, j/k but seriously one day there are going to be sparks coming out from under your car
On a serious note, when daily driving at slow speeds there isn't as much material removed nor is it distributed as much imho. I actually already looked back at your post that you referenced and agree with what you said back then. The clutch is still clamping, but maybe not as well as I believe the heat affects the springs.
Old Jul 17, 2013 | 08:30 PM
C6C3Vettes's Avatar
C6C3Vettes
Thanks for all of the feedback. Answers to a couple of the questions: There was no fluid under the car. The fluid was full but but pretty dark in color.
The dealer has ordered the parts and I'll post how it all works out.
Thanks everyone for your feedback!
To Clutch Pedal - Need some help.
