P0973 code 2005 a4
Old Jul 26, 2013 | 10:40 AM
Mrgchevyboy19's Avatar
Mrgchevyboy19
Default P0973 code 2005 a4
Check engine light came on in my 2005 A4. Tran seems to be stuck in two gears, Reading a PO973 code. Any suggestions what this might be and solutions.
Old Jul 26, 2013 | 12:55 PM
RicK T's Avatar
RicK T
P0973 --- 1-2 Shift Solenoid (SS) Control Circuit Low Voltage TCM -
DTC P0973 in Automatic Transmission - 4L60-E/4L65-E
I don't recall seeing that one before. I looked around here and found nothing. Looked on the net and found nothing related to Corvettes but a lot of Diesel trucks and Hondas.
Looks like a dealer visit is in order for proper diagnostics. Did find one case that turned out to be a simple neutral safety switch, but that is highly unlikely in your case.
Best of luck and please let us know what happens. )
Old Jul 26, 2013 | 11:41 PM
VET4LES's Avatar
VET4LES
P0973 = 1-2 shift solenoid (ss) control circuit low voltage TCM
This information is from the DTC codes for the LS2.
Good luck and keep us posted.
To P0973 code 2005 a4
