Valve stem seal spring??
Old Aug 4, 2013 | 04:02 PM
Nathanknorr's Avatar
Nathanknorr
Default Valve stem seal spring??
can anyone tell me what the significance/purpose of the little spring that goes around the rubber valve stem seal? I could guess but it seems that it could cause more harm than good.. doesn't seem like it puts much tension on the rubber itself? anyone? would it be wise to run with out them?
Old Aug 4, 2013 | 09:56 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I'm not sure what spring you are referring to, can you post a pic or drawing?
Old Aug 4, 2013 | 10:22 PM
Nathanknorr
http://www.ebay.ca/itm/Metal-Clad-Vi...6e5ef0&vxp=mtr
if you look on the blue rubber piece you can see a tiny spring that goes around it... just wondering about that little sucker.
Old Aug 4, 2013 | 10:33 PM
Gearhead Jim
St. Jude Donor '13
BEZ06 is the real expert on the TPMS and all its components, but I don't think the items in your link will fit on a C6.
Old Aug 4, 2013 | 10:39 PM
Nathanknorr
sorry not for the tire valve stem....for the exhaust valve stem. lol sorry for not being clear
Old Aug 5, 2013 | 09:53 AM
Gearhead Jim
St. Jude Donor '13
Got it, thanks.
Unfortunately, I have no clue about the usefulness of the spring.
Good luck with an answer, maybe post in C6 General if you don't get the answer here.
Old Aug 5, 2013 | 04:00 PM
victorf's Avatar
victorf
Spring is what makes it a "Mechanical seal".
Without it, you will not have a seal.
C6 General has even less technical knowledge. LS1Tech forum has the real gearheads.
To Valve stem seal spring??
