Dyno Pull Gone Bad....
Old Aug 8, 2013 | 08:05 PM
jpee's Avatar
jpee
Default Dyno Pull Gone Bad....
Video is on post #15
Well had the new FAST intake manifold installed, & put the car on a dyno.. on the 2nd pull all hell broke lose..
Flames from under the car went over the roof... We had a fire extinguisher and got the fire out instantly.. but the block now has a hole in the side that you can put your fist through
Cartek said the only thing I "MIGHT" be able to save would be the heads... MAYBE.. so I started looking on the INTERNET, & found a 2012 Camaro that was totaled and the LS3 had only 3100 miles on it ..
So I jumped on it and will be getting the LS3 for my 05.. I always wanted to see how my (A4) would run behind an LS3 with a few bolt on's...
The motor is ordered, & it should arrive next week in NJ until then I'm a desk jocky...
I got a video of the explosion and flames going as high as the ceiling, but don't know haw to transfer the video from my call phone th the forum...
I was lucky it blew on the Dyno and NOT at the BIG end of the track...
Old Aug 8, 2013 | 08:29 PM
bigterpsfan's Avatar
bigterpsfan
Save the video to photobucket and then copy and paste the link from photo bucket. Sorry to hear about the mishap!
Old Aug 8, 2013 | 08:41 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
sorry to hear jpee
Old Aug 8, 2013 | 08:44 PM
TLTONEY's Avatar
TLTONEY
That sucks blowing the motor!
Good job on going from lemons to lemonade!!
Old Aug 8, 2013 | 08:56 PM
EVRose's Avatar
EVRose
Sorry to hear about your disaster.
Upload the video to youtube. It works better than photobucket on videos.
Old Aug 8, 2013 | 08:58 PM
timd38's Avatar
timd38
FYI, the intake will not work on an LS3.
Old Aug 8, 2013 | 09:15 PM
jpee's Avatar
jpee
I got lucky & found a buyer for my FAST for the LS2... and right now CARTEK will port a OEM LS3 intake until I recoup some $$....
Old Aug 8, 2013 | 09:24 PM
dennis50nj's Avatar
dennis50nj
it will with ls2 aftermarket heads like tfs 225
Old Aug 8, 2013 | 09:48 PM
Gering's Avatar
Gering
Tolero Apto Victum
Old Aug 8, 2013 | 10:08 PM
John harlen's Avatar
John harlen
http://forums.corvetteforum.com/c6-t...s3-intake.html
Worth wasting the extra money on a FAST?
Old Aug 8, 2013 | 11:25 PM
HEATWAVE's Avatar
HEATWAVE
Dam that sucks , sorry to hear that happened,,
Ls3 will be nice tho
Old Aug 8, 2013 | 11:37 PM
HOXXOH's Avatar
HOXXOH
Too bad that happened, but better there than a lot of other places.
In true racer form, you accepted the problem and immediately look for a solution that will be better. This should be a good test using the A4, since it seems the quickest LS2's and LS7's use that trans.
BTW, unless your's is salvagable, you might start looking for a Corvette LS3 oil pan and pickup tube, since the Camaro one won't work in your car. Save your valve covers too.
Old Aug 8, 2013 | 11:55 PM
Corvettinator's Avatar
Corvettinator
Sorry to hear it, but you'll be faster after the rebuild.
Old Aug 9, 2013 | 07:15 AM
RichS's Avatar
RichS
Sorry to hear that John!!
Old Aug 9, 2013 | 08:06 AM
jpee's Avatar
jpee
Default Video
I hope this works...
Old Aug 9, 2013 | 08:51 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Wow... that sucks. Must have been a really sick feeling seeing that. I hope you get it going quickly. Good luck.
Old Aug 9, 2013 | 09:20 AM
sabastian458's Avatar
sabastian458
So what caused the piston/rod to break? Especially if it was just an intake change and tune?
Sucks that it happened.
To Dyno Pull Gone Bad....
Old Aug 9, 2013 | 10:12 AM
bigwoofersnet's Avatar
bigwoofersnet
Wow, bummer. Sorry to hear. I am also curious if you know what caused it?
Old Aug 9, 2013 | 10:21 AM
jpee's Avatar
jpee
Nope.. we haven't even gotten into the motor yet..it looks like a rod just let go.. it was at about 6500 RPM when it let go....
Old Aug 9, 2013 | 11:12 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
More likely a rod bearing or a piston seized, and the conn rod was the victim, along with the block.
