Dyno Pull Gone Bad....
The motor I'm getting only has 3100 miles on it, (almost new) and I'm no spring chicken in other words I'm an "old bastid" and I'm sure I wont be going to the track every week as I used to.. (its 100 miles each way for me to race at E Town)
I'll prob just port the stock intake, and use the Kooks Headers I have now and whatever it runs , it runs.. I can be going nuts and spending my savings to run .5 faster... if I was 20 yrs younger YES I'd go for a 427 motor... but in my situation I'll have to settle for an LS3..
correct me if I'm wrong...Cam = about $300
New Springs = About $350 +
New push rods = about $125
Now I'm at almost $700 + just for a cam "DONE RIGHT"
Agreed the shop is giving me a "killer Good Price" on labor as the motor is already out of the car...
But I've spent $5500 for the motor, and I need a new reluctor the 05 & 2012 are not compatible, so there is another 3-4 hrs labor is my guess..
Of course I'd like a better cam, but I'm on a "Fixed" pension, and have to keep the price in reason.... I already have Kooks, and a 2800 converter, and Cartek will port a stock LS3 intake manifold...
I'll have to see bottom line how much more it will cost me for a cam "DONE RIGHT" !
Patriot extreme gold springs are cheaper than that...I think...a cam you can get used from someone who's upgrading to a bigger one (they last now, unlike the old days when the lifters took a set and they were junk if you took them out and tried to use new lifters). You can reuse a cam.
Since you have the balancer off anyway for the reluctor it is zero add'l labor.
You should ask Cartek if they have any cams laying around. You might be able to score a freebie...
Heck given your hard luck story you might get a "pay it forward" from someone on the forum. Lots of guys have old cams laying around.
Bottom line is you don't need an aftermarket cam to run the 11.50 class.
BTW, ph# was in PM to you.
But DO keep in mind that jpee does NOT use skinnies nor remove the passenger seat of his well optioned C6 like many of us have done, heavy Optima battery and sometimes a nearly full tank of gas too (I've yelled at him for that part already LOL
).But even still, he can run 11.50s with a stock internals/bolt ons LS3 at E-town even at his raceweight. If not during June/July/August then at least during the rest of the year.
In my observations and reviews of many dyno sheets, a stock ls3 w/tune has the same power as a ls2 with headers & tune, and an ls3 w/headers has the same power as a ls2 with a decent sized cam.
Bad part about that cam is, and I'm guessing, it'll only add 10/10 rwhp/rwtq. Perhaps Cartek would have further input on that.
Is it worth the $$ the price for the cam is right.. gotta check on the install but it should be reasonable because the motor is out of the car..
Install on the cam should be free or close - they will have the engine apart putting in a new reluctor. Will only take moments to swap the cam and springs are easy to swap too.
If you put in a decent sized cam the LS3 produces 500 RWHP all day long on manual cars.
Your issue about resale with a cammed car is valid, dealers don't want them. You will have to sell it privately to someone who wants a cammed car. Those folks are out there, my friend just sold his built up z06 to a guy who wanted the mods and realized, he was getting them for 25c on the dollar by buying my buddy's car for slightly above what a stock car will go for. But it takes time to find that person.
For anyone doesn't do their own work, it will be an long term expense.
