St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Depends on total parts involved but 28-35 rwhp and 30-40 ft-lbs of torque.
Torque is going to be the biggest difference in the car and yes you will feel it. I would also say you should see a 1 mpg increase on highway driving too.
I have an 08 manual and with Vararam and tune with catted headers with Corsa Sports I saw 47 rwhp gain. 422 both hp/tq.
3 grand is a good estimate for having all the work done.
What mufflers would you use? This would be extra.
These mods woke up the LS3 pretty good. Big gains in torque from the long tubes.
If you think you will not be satisfied with the power save your money and get a blower. Then this brings up other aspects to consider.
Do your thinking first...
Wow that is some really good gains with those add ons. Coincidentally my plans are to put a corsa sport and one of those snake charmer vararams on too. I just bought the vette so im new but realizing these cars dyno high and respond well to bolt ons
Most novices, like me, think in terms of advertised crank HP not RWHP. When you add the 15-20% parasitic drag losses, the brake HP increases are 20% increased as well. Am I understanding that correctly? So, a 45 HP increase in RWHP equals 60 brake HP?
As an example, my 06 LS2 started out with 400 brake HP from the factory and was last dynoed at 386 RWHP or 463 brake HP. Don't you add 20% for the parasitic losses to determine the new brake HP? If so, is this calculation correct? 386 X 1.20=463 brake HP. Some even say automatics lose 25% in drag losses.
I didn't do a bone stock dyno pull, so I don't know what the RWHP increases were.
No, that's wrong.
All gains are measured from change in baseline dyno to post-tune dyno.
Here is my 08 A6. Stock vs Stainless works 1 7/8" Longtubes with 3" X pipe and C6Z Mufflers. Still through stock intake, planning on adding a Halltech MF103 over the winter and seeing where we are.
Is that without a tune? I'm think of getting headers and a tune with stock intake (08 ls3). I've read a ton on air intakes and just not sold on them just yet for the price right now.
I gained about 45 (manual) and have less than 2k in kooks, honker, tune - but that's shopping around hard and doing my own work. And something is wrong if you think 10-15% is negligible. It may not be a whole new car. Also a good tune on your auto will make it drive much better. (Well its subjective but most think it feels better. Will be faster)
sorry. I didn't mean to make 10-15% seem small. I just don't have working reference of that that feels like.
It is partially tuned... we got the fueling in line on the dyno but the car kept picking up knock retard no matter where we went with timing (Can see the dip right before 5000rpm on the post header pull) I know my exhaust is hitting the body somewhere at times and it seems the LS3 knock sensors are overly sensitive so we are going to fix the exhaust, get a new intake on it and desensitize the knock sensors slightly and see where we are in the spring.
Right on. Hopefully you get some good results. I'm thinking stock intake still.
