cai improvement
Old Nov 2, 2013 | 09:34 PM
dennis50nj's Avatar
dennis50nj
I have stated many times comparison within 10 ft DA almost 5 mph and 5/10s in the 1/4 mile, and how many of the top cars on the fast list have Vararam, just about all of them $400 dollars for that big of a gain and look how much faster you can pass
Old Nov 3, 2013 | 12:11 AM
GotVett?'s Avatar
GotVett?
Old Nov 3, 2013 | 12:26 AM
J Christensen's Avatar
J Christensen
Originally Posted by AIR_RAM
The gains from RAM AIR are more from the air being "Cooler" than the actual ramming effect.
So the gains you get will be from the fact that the air is COOLER... not because its "RAMMING"
The intakes that flow the largest amount of unrestricted cool air with the least amount of turbulence will aid in making the most HP!
SPEED SAFE, AIR RAM
I largely agree. After 100's if custom bike tunes when testing and experimenting with air filters, intakes and exhausts, the more free the filter/unrestricted intake/higher CFM the more the HP. Cooler air helped a very small portion.. = about nill.
On a Suzuki M109 the 2 stock filters flowed in the 40's CFM combined if I recall correctly, it's been too long since so I don't recall my numbers exactly. Cool air, even when tuned for it, makes a slight to negligible difference. Increase the CFM of the filters/un-restrict the air flow, and up the HP went. Max (increased) CFM/air flow for a filter which topped out the HP gains on a tuned stock M109 engine was in the mid-700's CFM filter. That was a huge filter sizing change over OEM, along with very large change in the intake system airbox. That large of a CFM change also topped out the f.i.'s. to the mid 90's (percent). Beyond the mid-700's CFM/airbox mod/no airbox, there was no more gain, as the engine had topped out for that type of intake mod.
Same for ZX14's, blown 14's, etc.
I suspect it a general rough 'rule'.
Old Nov 3, 2013 | 06:54 AM
dev1360's Avatar
dev1360
Cool air (lower IATs) help a lot because they allow the car to use more of its available power. LS engines start pulling timing at 88* intake temp. By 130-140* intake temp, you are down 25-30hp. That's a significant amount.
Cool air in=lower IATs=more timing=more power.
Old Nov 3, 2013 | 08:45 AM
dennis50nj's Avatar
dennis50nj
cooler air changes the DA, take a day like today. just change the air temp its in the 40s -875 DA make it 80 +1565 DA that's a DA change of 2440 ft, rule of thumb every 800 ft=3% hp gain or loss that swing would make a 9% gain THE VARARAM keeps cooler air starting line to finish line
Old Nov 3, 2013 | 11:04 AM
Chevy-SS's Avatar
Chevy-SS
Originally Posted by HOXXOH
Yep, that's it. If you do back to back tests, I would suggest you do something more like 20-80 so you don't involve traction issues. I did controlled tests on a friend's '07 A6. He made 2 passes at 12.38 and then propped the shroud and he made 2 more at 12.20 & 12.21. He ran better with a Vararam, but it wasn't the same day.
Were you using stock air filter for this initial testing?
Old Nov 3, 2013 | 11:26 AM
HOXXOH's Avatar
HOXXOH
I believe it was IIRC. He is (and his car) very consistent. He had a few mods, but was hesitant to try a CAI until I showed him the benefit of colder air. He's currently running 11.4's with a Vararam and a few more mods.
Old Nov 3, 2013 | 01:05 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
[QUOTE=J Christensen;1585333359]I largely agree. After 100's if custom bike tunes when testing and experimenting with air filters, intakes and exhausts, the more free the filter/unrestricted intake/higher CFM the more the HP. Cooler air helped a very small portion.. = about nill.
See the part in Bold....... I don't know about bikes but I do know about cars. From that statement, You Sir need to get educated because that statement is as far away from being correct as you can get.
Old Nov 3, 2013 | 02:03 PM
corvetteflier's Avatar
corvetteflier
That sounds just about right. 18 hp for a free mod. Add in Bullets, and you have the ~ 460hp the C7 claims--if not more, on an otherwise stock C6. Another reason the '14 didn't interest me at all. Go for the Z51 '14, and you add the advantage of being 250 pounds lighter in a C6. Not saying it isn't better on the track, but it certainly isn't in a straight line.
Old Nov 3, 2013 | 04:12 PM
HOXXOH's Avatar
HOXXOH
That's not 18 HP, it's .18 seconds quicker for the 1/4 mile. Mufflers are primarily for sound and rarely will add 4-6 HP. So don't expect a 430 HP C6 to match a C7 with just a couple small mods. Bone stock C7's have already posted better 1/4 mi times than the quickest C6 ever.
Old Nov 4, 2013 | 12:51 PM
corvetteflier
.18 quicker in the 1/4 equates to 18hp gain. Bullets, time and again, have been shown to add 15-18hp over stock. Chevy claims, conservatively, 6hp from the NPP which is 2.5" vice Bullets' full 3", still funnels exhaust through the muffler, and even has holes in the "straight" pipe that diminish its effect by venting exhaust into the muffler. IC engines are air pumps, and if you increase O2 in--cooling IAT being a key, and greatly reduce back pressure by having no mufflers, you add hp significantly.
Where did you get your info? I've seen no test anywhere that shows the C7 to be faster than 12.2, other than wishful thinking on some magazines' part and Chevy's unsubstantiated claim. It is also 5mph slower top end, and a tenth slower 0-100 even being a tenth or so quicker 0-60, depending on what you read. Just look at the times on the Forum for quick--lightly modded C6s, and they eat the C7 like a grape. And they run on all 8 cylinders, another thing that turns me off on the C7--aside from its being butt ugly.
Old Nov 4, 2013 | 03:27 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
I have owned 18 Corvette's and I have had almost every air intake made to date. My 2006 C6 that I just bought has a VR. So I take it apart yesterday to check the filter and it is truly a ram air intake. And water is not an issue. I have not and will not run my C6 at the strip, but the car does seem to pull a little harder on the top end at freeway speeds. And you can buy one new for way under 400 bucks!
Old Nov 4, 2013 | 03:49 PM
  #33
J Christensen
[QUOTE=ls1121;1585336324]
Well, those statement were in reference those bikes. I was posting it up here for part of the discussion to see how it related, or not. As it appears there is a difference between the two, those bikes -vs- C6's, as in the PCU pulling timing
in relation to the C6's... then it obviously does not apply. It's great to learn something new. That is what forums, discussions and discovery are all about = more education.
woohoo to you as well.
Old Nov 4, 2013 | 06:00 PM
  #34
AIR_RAM's Avatar
AIR_RAM
If you where to take the scoop and stick it out from the vehicle and plumb it directly to the throttle body it would only make the intake a true "COLD AIR INTAKE" there would be ZERO significant "RAMMING" effect to conclude "RAM AIR" is creating any gains what so ever.
HOWEVER, gains would still be made due to the COOLER AIR being drawn through the intake... The snake oil sales just get tiring, and the few who have no idea about air flow are easily swayed.
I'm in no way suggesting the VR is a bad intake... It may indeed be the best "COLD AIR INTAKE"... but its gains would 100% be due from COLD AIR and not RAM AIR. Suggesting its a "RAM AIR" intake is misleading and untrue/Unfounded.
If you want to call it ram air, please measure the boost created from the "RAM AIR" and post that number up for all to see... Please post your means of measurement as well.
Without posting the BOOST amount created by the "RAM AIR" all you have is a good cold air intake!
Sorry, It takes more then a sales pitch to mislead some of us.
SPEED SAFE, AIR RAM
Old Nov 4, 2013 | 06:31 PM
  #35
dennis50nj's Avatar
dennis50nj
SPEED SAFE, AIR RAM
how did i gain 5mph and 5/10 with cold air the da was within 10 ft same cold air
Old Nov 4, 2013 | 06:35 PM
  #36
AIR_RAM's Avatar
AIR_RAM
There are more variables that effect ET than air temp and DA... Perhaps you had less fuel in the tank, perhaps the engine temp was cooler... Perhaps the tires gripped better... Perhaps the track prep was better, perhaps perhaps perhaps...
The bottom line is that its impossible for you to have created ANY boost from the ramming effect... So, your gains where due to a better flowing intake providing more Non turbulent cool air than the previous... but not RAM AIR... Calling it RAM AIR is misleading... You clearly have a true "Cold Air Intake".
I had a 2002 Dodge Ram with a 4.7L engine... It would run 2MPH and .2 quicker ET by simply removing the air filter. So your gains are not so hard to believe with the intake swap...
SPEED SAFE, AIR RAM
Old Nov 4, 2013 | 07:00 PM
  #37
dennis50nj's Avatar
dennis50nj
SPEED SAFE, AIR RAM
http://en.wikipedia.org/wiki/Ram-air_intake
To cai improvement
Old Nov 5, 2013 | 06:09 AM
  #38
AIR_RAM's Avatar
AIR_RAM
Originally Posted by dennis50nj
LMAO... Really?? Well we can't argue with the scientific response of Wikipedia! FYI, anybody can enter a definition Into Wikipedia.
That was a first... It made me spit my drink out!
SPEED SAFE, AIR RAM
Old Nov 5, 2013 | 06:35 AM
  #39
dev1360's Avatar
dev1360
5 mph?
I'm hoping to gain that with a cam.
Someone call Halltech. I was ripped off.
Old Nov 5, 2013 | 08:46 AM
  #40
dennis50nj's Avatar
dennis50nj
Originally Posted by dev1360
5 mph?
yes Sir read the fast list, its all documented I hope to gain the Max with each mod, I ran 10.62 with bolt/ons then only 10.59 with cam, traction problems, and yes I believe you were, all the fast c6s have vararam
