cai improvement
On my 98 Z28, my Free Mod to allow a freer air flow that cost me nothing gave me the same HP increase as did the fancy hood with scoop that GM installed on the SS model. If you look at the photo to the left you will see my SS hood. I installed it because "It LOOKS Cool" did not give me any more HP.
YES... EXACTLY!!!
I am stating a fact that your gains have absolutely NOTHING to do with Ram Air.
Your gains come from cold unrestricted non turbulent air!
Your air happens to have direct flow from a cold air source... Your receiving ZERO gains from RAM AIR! Your gains are all due to the cooler non turbulent air source!
And yes I find it funny that your unable to understand this simple fact. Although not common sense for most, it's certainly easy to understand and then apply it to your own common sense and personal reality.
Im willing to bet you would also argue that engines need back pressure to make power...? Just pointing out that simple minds are easily misled! Having a good understanding theory of operation will not only help protect you from being misled, it can also save you money and assist you in making informed decisions when selecting modifications. Understanding theory of operation will also aid you in making your own "do it yourself" modifications.
Just trying to help you understand where your gains came from and more importantly where they did not come from.
SPEED SAFE, AIR RAM
And yes I find it funny that your unable to understand this simple fact. Although not common sense for most, it's certainly easy to understand and then apply it to your own common sense...
SPEED SAFE, AIR RAM
funny the time slips prove that not to be true
so now prove other wise dont just say it and expect people with experience to believe it.
so now prove other wise dont just say it and expect people with experience to believe it.I never said the VR was a bad COLD AIR INTAKE... I never said your gains claimed where false. I'm happy you clearly have enough money to throw at your car and that it's as fast as it is even with your limited understanding of theory of operation of how your modifications have effected the performance. Hey, when you got money to burn your able to pay someone else to do your thinking for you... I get it.
All I can do at this point is smile and give you a big thumbs up... You have a sweet *** ride and I have to appreciate you made a great choice in owning a Corvette. However you clearly have no idea of theory of operation or how your mods work together. Just toss enough money at it and it will stick! This approach has clearly worked for you.
This is why vette owners have such a bad reputation with other car groups.
With money comes ignorance, the more money you have the greater the ignorance. They say it's "bliss".
And before you go on with your attempts to discredit me, I took the passion I have with performance vehicles and went into business with it. We (AIR RAM PERFORMANCE) have been in business since 2002 and have been very successful since. Much of what I know has been verified and proven at the track.
SPEED SAFE, AIR RAM
then so be it. I'm just one of those people that have been in this for a long time and I know better. That is all.
Spend and believe whatever you like it's your car and your money.
It's not uncommon to see 2-3MPG increase for every 10hp gained.
Any time you can make your engine more efficient you will be rewarded with better MPG or ETs depending on where you like to use it.
I also agree with LS1121 that there are many FREE mods that can be done to increase performance... Getting fresh cooler outside air to the filter location is trick number one!
But I also know that the resonator (intake muffler) robs HP by creating turbulence in the intake which is how it muffles the sound... So removing the resonator and blocking the holes would be free but not as clean and eye appealing than an aftermarket cold air intake. So removing the resonator alone is worth 8-10 RWHP.
SPEED SAFE, AIR RAM
ignorance is not a bad word... We are all ignorant on something... It's not knowing by choice... I'm not a plumber, if you had asked me to sweat some pipes together my ignorance on the subject would be made painfully clear.
SPEED SAFE, AIR RAM
I've been racing since 1958 and have an extensive engineering background, so I guess I'm not the young dumb rich kid you believe.
SPEED SAFE, AIR RAM
About common sense that unfortunately not too common. Even Einstein couldn't find his way home if he walked more than a block or two from his house.
But do not change out the air filter for a high flow filter.
All high flow aftermarket air filters show a high accumulative gain in dirt ingestion.
While they increase air flow at high RPM, the filters used always increase dirt ingestion across the entire rpm range.
This has been proven with oil analysis (higher silicon numbers) and independent air filter tests.
SPEED SAFE, AIR RAM
. are you for real?, but back to the question, if your iat is at ambient after the first 100 ft of the 1/4 mile with the stock intake filter then there is no difference in the delivery of the cold air in the last 1220 ft so just the cold air of the vararam in the first 100 ft nets 5/10 5 mph
dont you sell an air intake, what is all this air ram stuff your screen name your store or the name of your intake system.
dont you sell an air intake, what is all this air ram stuff your screen name your store or the name of your intake system.Your gains came from:
COOLER, UNRESTRICTED, NON TURBULENT AIR.
Your gains did not come from;
RAM AIR
I hope that was not too much reading for you.
I concede at this point.
SPEED SAFE, AIR RAM
