It's about the same as buying the $1800 option for a set of wheels that don't add any performance, but just look different than the base wheels.
$50K will buy you lots of hookers and drugs or 3 smart cars or 1 Corvette. Freedom of choice still exists to some degree.
Headers were always a Performance Upgrade to produce more power and still are for most. I just never realized how GOOD the Chevy exhaust manifolds (ZR1,Z06) were. Comparing fancy wheels to a set of Headers is an attempt at changing , confusing the issue here. We are talking about HP not body appearances. Lets try and keep in on the Green.
Before I make a purchase I calculate the value or ROI of any part or service to see how much money I'm paying for every horsepower and/or every ft lb of torque. In my opinion a tune always comes first as it usually shows good increases on dyno, on track and butt dyno giving better off idle throttle response and snappier through the revs. Say you pay $500 for tune and see 20rwhp gain that is $25/rwhp (Spend / rwhp = $/rwhp. If headers cost $2000 installed and retuned with 25rwhp gain your cost is $80/rwhp. Say you install centri-supercharger from A&A/ECS/ProCharger for $8000 and yield 160rwhp that is $50/rwhp (I factored in $6200 advertised installed/tuned price by forum vendor along with another $1800 twin disc clutch installed). 160rwhp is attainable by centri unit on pump gas only with plenty of clutch to spare. Obviously my numbers are estimates but pretty close to real world dollars and values. Qualify you ROI (return on investment) instead of impulse buying and you'll decrease your risk of disappointment and buyers remorse.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by village idiot
Not sure that's a very fair way to compare the two Changing pullies because you the vacuum gauge at the manifold reads different....
But on any forced induction setup it is going to matter if you want to get right down to comparing apples to apples. Actually you would want to see what the car would do with and without a boost change.
The fact of the matter is though, in most supercharged applications a change in back pressure will result in a change of measured boost. Same thing with changing down pipes and post turbo pipes on a turbo car.
You sound like a Degree in Buss. Managemant. i like the way you think.
He will be shocked when he finds there is no ROI on Corvette mods. Just a thinner wallet.
It just Impresses me when people actually back up what they say with thought and facts. many people just believe things because other people say it. Kinda like if someone says some BS and says it over and over, they think if they say it enough times that it will suddenly become true.
In one or two of the above posts it was mentioned how much $$ you spend "per HP" ....
I'd bet my house WJ or any top shelf Pro Stock driver would pay $1000 "PER HP"
I'm dead serious...if you were able to GAR-UN-TEE a Pro Stock owner/Driver.. you could add 30 more HP to his 500 ci motor he would gladly pay you $30,000 ...
I made 396 HP with my LS2 with a CAI, Kooks Headers, and a tune.. & I blew up that motor.. I'm picking my new motor in a week or two, it will be a stroker (403 ci) with a FAST Intake, ported and polished 243 heads, and a cam (Not crazy aggressive) something I can drive on the streets ...I expect to make close to 500 RWHP..
I'm going to the shop tomorrow as they are going to dyno another car that just had the "EXACT SAME ENGINE" installed.. so I should see how close to 500 I'll be.. but everyone I've spoken to agreed that Long Tube Headers are the way to go if your looking to make as much HP as you can...
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Ah I am cheap ..... I lusted after a set of LG long tubes but being a cheap skate I went with a complete Z06 Exhaust for approximately $ 900.00. I added a cold air intake, fast 90, bilstein shocks, 2800 stall, converter, tune, line lock, and a set of MT drag radials.
The car went a best of 11.3X with out any weight reduction and went 11.17 with GTO spares on the front, no pass side seat, almost no gas and all my stuff removed from the car. I race at Atco so I usually have the benefit of a decent DA.
For those of you who do not need every bit of horse power and rather not be hassled at state inspection a Z06 exhaust is an option. If you want that extra HP then go with the headers.
who the HELL is talking about pro stock here, we are talking about the average Joe and his DD. Why is it some people always try to change or confuse the subject. OK $ per $ I think the stock ZR1 exhaust system puts any of those $2000 header systems to shame. That's what the man was suggesting. Is that simple enough for you to understand?
In my experience using LS7 manifolds over a full length header produces roughly 40-45% of the power gain.
Not a bad $ per HP increase!
That said, long tube headers are hands down better HP per HP.
All depends on your goals, financial placement, or simply what you wish to spend your money on.
only the purchaser can decide that for themselves, but they shouldn't ignore the facts believing that a LS7 manifold will make as much or more power than a well designed long tube header. I have yet to see a C7, Z06 or ZR1 not gain power when they get headers installed as efficient as the factory "shorty" headers are. Same can be used in a comparison to the aftermarket shorty headers vs full length designs. You get half the gains, but are still leaving some power on the table. I definitely recommend them for guys on a budget, sleeper status or to pass visual smog inspection.
Just exactly what type of comparison would be acceptable to you? Obviously you're hung up on money, not the relationships of what money can buy.
I can take a stock LS3 car and make it run 3 mph faster in the 1/4 mile for a couple hours of my labor and $0. Try calculating out that HP and value gained.
Thanks, I was merely referring to the "power returned per dollar invested". Everything ties back to almighty dollar so make those mods count
Originally Posted by dennis50nj
But he still put the kooks lt headers on his car
Yes and the results of that install proved without question that on a basically stock setup you will not achieve a good power increase per dollar invested. At that time I had factory manifolds with $160 off road x-pipe welded in. Spending that $2k+ on cam install would have yielded more power.
....I'm going to the shop tomorrow as they are going to dyno another car that just had the "EXACT SAME ENGINE" installed.. so I should see how close to 500 I'll be.. but everyone I've spoken to agreed that Long Tube Headers are the way to go if your looking to make as much HP as you can...
The Pro Stock analogy is totally irrelevant but I agree with needing long tubes to make maximum power. Long tubes eventually work they way into every max effort build to squeeze out every last horsepower. I've made my point in preceding posts addressing dollar invested vs. power gained, it is valid, quantifiable and undisputable. All that said, spend your money how it makes YOU happy.
Adding to this, it only takes a look at dyno graphs to illustrate where power is gained or lost by LT's compared to LS7 manifolds. Gains / losses depending on primary diameter of LT's and RPM of measurement.
I'm not "hung up" on anything. The conversation starts as a simple question or remark about a comparison a magazine did between ZR1 manifolds and a set of headers and then all of a sudden people (Jpee) turn the conversation to a comparison between stock exhaust manifolds and a Pro Stock Track motor... what is he thinking, and then come here and start breaking my *****. I'm installing a ZR1 exhaust on my LS3 and thought the conversation was interesting, that is ALL. Some of you guys here think if everybody does not agree with what you thing then we are all stupid. Take it easy it's not that important.
I was at 384rwhp with Cai and gutted cats. After upgrading to ls7 manifolds, cats, midpipes, Mild(seriously...mild) cam and tune Im at 443rwhp through stock non npp mufflers. I know headers will see more power, but for the cost its not worth it to me for what im doing with the car. Car is quiet, drives near stock...but much more power
I got my manifolds and cats yesterday and the X pipe from a 2011 ZR1 came today. I might start the work next wednesday while I off for the Holiday. Contacted a muffler shop to do the reduction for me, they said $65 per hour was their labor charge.
