Years ago N2O was a DIY. I bought an NOS #5115 kit designed for V8 Mustangs and adapted it to a '94 Suzuki Swift GT (1100cc 4cyl). Worked like a champ with the right N2O and Fuel jets. Transfered the kit to my '98 Ranger PU then sold the kit to a guy with a V8 Mustang in 2000 when I bought my Firebird Formula. Pretty crude kits, injected N2O and fuel into the throttle body behind the MAF, no tuning, no timing pull. Supposed to be a 100HP shot for the Mustang.
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Up to 100 dry shot you should be easily DIY. Beyond that is it still DIY but at a more difficult level because you are going to want to go Wet Shot.
Check out the C6 Forced Induction/Nitrous section for a lot more advice.
Thanks for the reply's, i will check out the F/I section.
dennis50nj, what brand sys are you using?
I have looked at NOS, Nitrous Express, seem similar i will keep researching, also what size bottle and what did you do about the tune?
Thanks, Rob
