What's the best Headers?
Old Dec 10, 2013 | 12:36 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default This is the ony headers we sell...
Originally Posted by MikeDost
Well first I live in California.."smog restriction."
I wanna add headers (possibly Kooks) to my 2005 C6 to start adding more horse! Sooner or later a Cam.... What's the best bang for the buck? Thx
So far: Callaway Hooker CAI
Flowmasters
Manual trans.
This is the ONLY header we sell...
Chuck CoW
Old Dec 11, 2013 | 11:39 AM
briancb1's Avatar
briancb1
If a quality set is too expensive new, search for a used set in good condition.
Old Dec 11, 2013 | 03:19 PM
elizavette's Avatar
elizavette
i live in cali, went with LG long tubes - happy with them
Old Dec 11, 2013 | 05:35 PM
jpee's Avatar
jpee
Will the Zo6 mans hook straight up to the LS2
And california doesn't allow long tube headers. A bunch of **** out here and their emission laws are garbage! How much hrspwr does it generate? Thx
I don't know "HOW CLOSE" the Ca. emissions shops look, but here in NY they just plug into the plug under the steering wheel...
IF they did have to do a "VISION" inspection I know the owner well enough so he would look at it as well as Ray Charles & I'd pass...
It was the same way in Ct. they never busted balzz if you knew them...
Cant you get to know someone at the inspection station and when you need inspection he will have poor eyesight.. I've been doing it that way since MV Inspections started.. I now have KOOKS long tube headers (with cats) and inspection is a wiz.. no problems at all..
"IS EVERY INSPECTION STATION IN CA> THAT MUCH OF A DICK ??"
Old Dec 11, 2013 | 06:51 PM
J Christensen's Avatar
J Christensen
Wish i knew. I haven't had a car inspected since I don't know when. I need to checkout that when you first go to get checked, does that 'check' then remain in the 'system' /state wide, so if you go to another location, they'll have a record or the other stations smog check/if you got caught at another smog station?
Old Dec 11, 2013 | 11:48 PM
J Christensen
Originally Posted by C6_Demon
I wouldn't bother with headers out there. Get a tune, supercharger, etc. Headers and California are a bad mix.
Good point.
Some how some CA folks are avoiding the CARB/smog problem. All tight lipped.
Old Dec 12, 2013 | 08:16 PM
jpee's Avatar
jpee
Originally Posted by J Christensen
Good point.
I've heard $$$ will do wonders if you go to the "RIGHT" shop or inspection center!!!
Old Dec 13, 2013 | 01:50 AM
croatbob's Avatar
croatbob
How can headers be illegal but a cam n blower not be? Headers don't cause more greenhouse gases while blowers n cams do. Wtf?
Old Dec 13, 2013 | 07:54 AM
CI GS's Avatar
CI GS
Pfadt. Without question. Best fit and best quality welds I've ever seen. I put them on my 13 Vette in my garage by myself without any help. There was no need to adjust anything and they don't hit or rub anywhere. The torque from the tri-Y design is amazing. I have ARH 1 7/8" headers and ORY on my 2008 Denali AWD and they are good quality and generally fit okay, except the one of the primaries rubs on the steering shaft. That cost me a new steering rack before I figured out what it was. I had to slacken the steering shaft assembly and pry it over a bit to keep it from rubbing, although it still does a little bit when it's in reverse and the drivetrain torques over to the left. Very annoying. If Pfadt offered headers for my truck, I would buy them in a heartbeat. I'm assuming they fit much better on the vettes as everyone that has them seems to like them. I just couldn't take the chance based on the experience I had with my truck. Just my 2 cents...
Old Dec 16, 2013 | 09:43 AM
B-Vette's Avatar
B-Vette
I had Kook headers on my C5 and was pleased with the result but they were a pain to install. I had the headers Jet-Hot coated, installed a starter heat shield and had Elites Thermal Abs added as well. I'm not saying you need all the extras but the heat transfer was never an issue for me.
Old Dec 16, 2013 | 09:56 AM
B-Vette's Avatar
B-Vette
Old Dec 16, 2013 | 04:14 PM
Pfadt Racing's Avatar
Pfadt Racing
Thanks for the support! I suppose I should tell the engineers to make some truck headers this year?
To the OP: We make amazing headers here at Pfadt. Considering time/labor/expense, I easily consider out Tri-Y to be a "bang for the buck". However, in California there are some additional considerations, and our tune products might be a better option. Feel free to contact me anytime with questions,
Pfadt Race Engineering
888-972-2464
info@pfadtracing.com
Old Jun 28, 2014 | 05:25 PM
  #33
Vet Interested's Avatar
Vet Interested
No issues getting through the smog test??
Old Jun 28, 2014 | 05:40 PM
  #34
Jims12Screw's Avatar
Jims12Screw
Default American Racing Headers
By far the best customer service I have ever had the pleasure of dealing with. My previous car was a 2007 FOrd Mustang GT with ARH long tubes, and a Procharger. 2 days after picking her up I could hear an exhaust leak, Long story short is installer blamed warped franges, I call ARH and bring the car to them, They emove while i watch show me how flat the flanges are and then show me the HUGE globs of RTV used to hold the gaskets in place as well as halp the studs were loose. They reinstall properly and never an issue again. Top notch company, Made in the USA, Great products. I am a customer for life
