2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by 1MEANGS
Hat's the easiest / best way to hook this up for a clean install... Any advice & pics would be great... Thanks - Eric
There's not a whole lot to it really, just plug into the coil packs and then find an activation source using either a ground or hot wire.
If the car's a stick then you'll probably wanna hook it into the clutch position sensor/switch and if it's an auto like mine you can do what I did and install a switch on the brake pedal.
I'm not at home right now but if you wanna see how I mounted the switch, email me later and I can send a couple of pics.
Do you recommend hooking it via a momentary switch, so i can activate off and on, that way its not always on while i push the clutch in?
Ok its been a while since I've done one. I want to say I had a switch and the clutch switch wired in. I think you only need the clutch switch, but I liked being able to turn it off. I also had a line loc, and the switch armed the 2 step and the line loc
