Yank converter trouble!!!!!
Old Jan 8, 2014 | 03:35 PM
rsigue's Avatar
rsigue
Default Watch the drip
What i did was to jack the car up till is was level, fired it up let it warm up. Shifted it through the gears, pull the drain plug no drip. Kept putting oil until it started to drip from drain plug. I kept checking how many and much oil i was putting in ,until it started to drip. Just a little over 3 quarts , thats how i reached my number. Its too bad they couldnt design this unit with a dip stick..........
Old Jan 8, 2014 | 03:36 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by pit-man
Dave is awesome
Old Jan 8, 2014 | 07:12 PM
HOXXOH's Avatar
HOXXOH
OK. I see you just followed the standard procedure. Just by the way you wrote before, it kinda sounded like you knew it was 3 quarts low before you added anything. That's why I wondered how you knew that.
Other than having to access a dipstick through an opening in the trunk/hatch, it'd be a pain to add fluid there too.
Old Jan 9, 2014 | 08:39 AM
rsigue's Avatar
rsigue
Default yes
Real pain in the butt , to check tranny fluid but we have to do it. Drove it some more last night, even got on it a little bit. Still the leak has not come back........
Old Jan 9, 2014 | 10:39 AM
dennis50nj's Avatar
dennis50nj
your luck has changed
