The car is a 2010 Grand Sport convertible, automatic transmission, and supercharged. I'm told it has 630 hp at the crank. How much would this convert into at the wheels? I do not have the dyno sheet and I assume they converted it.
I've heard some general conversion factors, but I'm wondering if anyone has actual numbers on a similar car. It seems like the manual car is pretty efficient but I do not know about the automatic.
Every Dyno is different. The most common Dynos lose 60HP flywheel to rear wheels for a standard trans and 70HP flywheel to rear wheels for an automatic.
I.E.;
An LS2 would be 400HP flywheel down to 340HP stick and 400 down to 330HP Auto.
An LS3 would be 430HP flywheel down to 370HP stick and 360HP auto.
It's a fixed/percentage imo and hard to put an exact number on it, but make sure you are comparing the same correction factors as many chassis dyno numbers are SAE and engine dyno numbers are STD.
I've always leaned towards this theory myself. If a 400 hp LS2 loses 60hp through the drivetrain, which is 15%. Why wouldn't a 500hp LS2 lose 60hp through the same drivetrain and not 75hp(15%)? Why does the percentage stay the same with the power increase?
All other things equal its a fixed HP loss, NOT a percentage.
The A6 takes 10 HP to run, whether it's 10HP from a 400HP LS2 or a 436HP LS3. Same with the rear gears, a fixed amount of HP, NOT a percentage.
I see your reasoning, but not sure it works that way.
There will be parasitic drag as the engine tries to turn itself and the transmission over faster.
Just like how doubling horsepower doesn't mean top speed is doubled. That is an extreme example, but the transmission and gearing is spinning through fluids. The faster you want to spin it, the more effort and power it will use.
Has to be a percentage, example, if a 400 crank horsepower motor looses 60 horse thru the driveline, a 100 horsepower car looses 15 horsepower not 60, cannot be fixed
I think he means it's fixed for a certain engine and drivetrain combo. Could you even make a 400 hp LS2 only make 100 hp?
Personally I believe it starts off at, lets say 15% (60hp), and then the percentage starts to drop slightly as the power increases but not at the same ratio to sustain the original 60hp loss.
These are just examples of my theory based on almost nothing. Kinda thinking out loud.
I agree it's hard to calculate exactly, but you are still accelerating mass which takes power even though the more you have the faster it will happen...there is still resistance and it is not the same for every combo
Absolutely, you can get any engine to produce less than 100 HP. How much HP does it take to run the car down the road in low gear at 7 mph? Not very much, well less than 100. A drive train will have the same amount of friction loss no matter what the peak HP of the engine is. At a certain speed the HP loss will be the same no matter which motor is turning it. For instance take a C6 GS Vs a C6Z06 in 4th gear at 60 mph on a level road. Drive train loss in both cars will be the same.
I.E.;
^Plenty of LS3 cars have put down 380whp in M6 trim and 370whp in Auto trim. It happens, but to your point every dyno is different but many of them have been within 5hp of each other stock for stock.
