LS3 modifications and ¼ mile results
Old Jan 20, 2014 | 11:25 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice setup you have
Old Jan 20, 2014 | 11:35 PM
BSPC608's Avatar
BSPC608
Originally Posted by ShaneFap
Hoosiers over the mickeys all day.
I could never get my 295/45/17's MTs to hook like the hoosiers and played with air pressure alot.
Btw why did you go with the ID850's? My car made 476 and im still in the low 80% IDCs
Tuner suggested them because of the accurate characterization tables for GM PCM tuning. ID850's are at 60% IDC.
dennis50nj's Avatar
dennis50nj
You got that c6 flying Brian, great job and I'm sure you got a lot left in it
Old Jan 20, 2014 | 11:54 PM
HOXXOH's Avatar
HOXXOH
Originally Posted by LAK3RS
Which Hoosiers do you have exactly? Are they streetable at all? I'm just trying to decide on the best tire to throw on a set of 17x9's, and since the TSW's don't weigh much I was thinking of picking a set up to throw some MT 275/40/17's on there, but if the MT 315/35/17's will fit - I'll try them out. Though, you have me curious about Hoosiers now...
Are these yours?
http://www.summitracing.com/parts/hoo-17332/overview/
Streetable? Only if you don't drive much. The reason Hoosiers average 6# lighter than MT is the tread thickness. Don't expect more than a couple thousand miles from the Hoosiers.
Assuming you have a narrow body, the 315's will be OK for the track, but may hit when street driven over bumps and hard turns. They also crown on 9" wheels and somewhat on 9.5" ones.
The 275 Hoosiers will easily hold 550 rwhp on a 9.5" wheel.
Old Jan 21, 2014 | 12:04 AM
LAK3RS's Avatar
LAK3RS
I just don't have any intentions of changing wheels/tires at the track, but obviously Hoosiers seem to be the most popular tire around here and it's also well proven.
Moreover, I guess I meant to ask if they are somewhat decent for throwing on the car and driving it 100 miles round trip to the strip.
I'm considering sticking with MT ET Street radials just for this reason. It's just extremely enticing to get the Hoosiers due to the insane amount of proven performance a lot of these C6's have shown with them.
Old Jan 21, 2014 | 12:55 AM
ShaneFap's Avatar
ShaneFap
I understand that. I had them in my old G8 and they are top notch.
I ran the 315/30/18 Hoosiers and the 315/35/17s
The 17" version is wider for sure and with the aggressive offset of my 18" 10.5" TSW i would get some contact only at the track it seemed
I would say the 10" RTS with the wider 315 17" version sat outside the fender about the same as the 10.5" 18" TSW with less offset.
P315/30R18 11.0" 26.0" 81.7" 11-12" 11" 11.7" 25
P315/35R17 11.5" 25.6" 81.6" 9-11" 11" 12.6" 26
The hoosiers will not last long at all but in my mind are very streetable in dry weather. I've driven drs and full slicks all over on the street with no issues.
i just put on the 28x10x17 On my car since i have the 3.42s and should put me where i need to be in 4th thru the traps. I would have gone back to the 25.6" DR but just wasn't tall enough with the A6 and 3.42 with the rpm im turning.
Old Jan 21, 2014 | 01:49 AM
HOXXOH's Avatar
HOXXOH
Yep, they're the best choice for driving to/from the track.
Old Jan 21, 2014 | 05:40 AM
CTD's Avatar
CTD
You might find some additional power getting the IDC back up into the 80-90%. With the injector on longer better atomization occurs. There are injector timing events adjustments that can be made but it's easier to go with a smaller injector.
The characterization tables of the GM injectors is excellent, that is what the aftermarket tries to achieve. The manners of your car won't change with LS3/7 injectors.
Old Jan 21, 2014 | 05:20 PM
1BADLS's Avatar
1BADLS
Nice. I'm glad I hooked you up with James Karger for your new tune.
Old Jan 21, 2014 | 07:53 PM
PRE-Z06's Avatar
PRE-Z06
Plan to be at the track this weekend, the GTO spares bought them with radial tires which weigh 34lbs versus 30lbs with bias ply. Still 6lbs less than current set up.
Good deal, looking forward to it running faster even if the skinnies aren't as drastic of a difference than with stock wheels
I thought the reason the Hoosiers are lighter is because they are nylon belted unlike the steel belted M/T?
Old Jan 21, 2014 | 11:25 PM
HOXXOH's Avatar
HOXXOH
The 275/40x17 Hoosiers lose 4# from new to cord. That's roughly 1# per 1/32 of tread. Steel belts weigh approximately 1.5#. Hoosier advertises their 275 as 21#, while MT lists the same size at 28#. If we give the MT the benefit of 2# of steel, there is still a 5# difference. Even if we allow 1 or 2# for extra width or shoulder, the remaining 3# would indicate an additional 3/32 of tread depth.
I can neither confirm or deny that hypothesis. Maybe we can get someone to weigh new MT's when new and again when corded.
