LS3 to C6 ZO6 level
Old Mar 14, 2014 | 03:44 PM
  #61
FireGS's Avatar
FireGS
Originally Posted by Amwellls1
Hey how did I get drug into this
Because you drive a "poser" car too
Old Mar 16, 2014 | 11:36 AM
  #62
Amwellls1's Avatar
Amwellls1
It's all good. Never bought the GS to race, it will never be a Z06 nor did I ever intend it too. The weight and the power under the curve puts it at a disadvantage but for the minimal mods I did I am happy with it
Old Mar 17, 2014 | 04:19 PM
  #63
BOO666's Avatar
BOO666
I love my lil gs
Old Apr 22, 2014 | 12:38 AM
  #64
dewilhite's Avatar
dewilhite
Originally Posted by coSPEED2
You do not have to get such a huge cam to make parking lot driving a disaster. With the requisite list of tools needed you can change the cam in a weekend.
If you get our HPT/tune combo, you can have it running 100% in that same weekend...given some spare time of course.
I have 2012 GS manual with a few simple bolt-on mods already done for the engine (SLP exhaust and induction and a new tune). I am considering bumping up from that to something like mentioned here that would rival Z06 power/torque while maintaining stock driveability (and hopefully not totally void my remaining warranty!). I would budget maybe $3-5K. What would you recommend as best option for that price? Thanks very much.
Old Apr 22, 2014 | 07:36 AM
  #65
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
"heres one of our builds @ extermination
mods
engine
* LS3 427 ci short block (callies 4.1" crankshaft - 6.125" compstar rods - 4.070" manely -7 flat top pistons)
* TrickFlow 235cc CNC Cylinder Heads (650
Lift Dual Spring - 7.500 Hardened Pushrods -Milled to Spec-67cc)
* vengeance racing custom camshaft 255/259 624/624 114 LSA
* yella terra 1.7 rocker arms
* caddy lifters
* SLP under drive pulley
intake
* SLP cold air intake
* 92mm F.A.S.T big mouth T/B
* 92mm F.A.S.T intake manifold
exhaust
* hooker long tupe headers 1 7/8
* 3" off- road Y pipe
* BOSCH Oxygen sensors
* Corsa Cat-Back 3.5 serious
fuel
* 255 walbro fuel pump
* F.A.S.T fuel rail
* 38lb injectors
ignetion
* LS7 coils
* MSD 8.5 mm plug wires
* NJK TR6 spark plugs
cooling
* Bee Cool radiator
* mezire water pump
NITROUS
* TNT nitrous system adjust to 200hp
* HARRIS speed works plate system adjust to 100hp
*stand alone fuel system (RCI fuel cell - bosch fuel pump - fuel filter - AiroMotive regulator - VP NO2 race fuel 120+ octane )
electrical
* 2 bar map sensor ---> mafless tuning
* AEM Wideband
* MSD Timing Twister
* MSD Digital RPM Activated Window Switch
* Caspers Electronics V-Plus Volt Booster
drive line
* spec cluch kit stage 3+
* spec aluminum flywheel
* tick performance master cylinder ----> DAMN i like it , awesome master cylinder
* RAM slave cylinder
* Spohn Perf. Top-Gun Driveshaft
* Moser 12 bolts rear end 3.4 ratio
** timing 21 degree **
** compression ratio 11.3 :1 **
** tuned by Ahmed Albahrainy **
actually we faced a problem with the MSD timing twister or let's say with the wires connections
Therefore, we have not increased timing coz there two stages on board
Dyno results
539 rwhp
521 torque
1st stage (low pressure bottle) air/fuel ratio when spraying : rich
722 rwhp
781 torque
2nd stage (low pressure bottle) air/fuel ratio when spraying : rich
794 rwhp
821 torque
dyno clip
794rwhp-821tq
idle clip
Old Apr 22, 2014 | 08:37 AM
  #66
petsur's Avatar
petsur
I just finished upgrading my '13 Grand Sport mn6 with a set of PFADT headers and a custom cam from Tick Performance. Specs were 219/232 and something like .584 .607 lift 113 +5 LSA.
Baseline data 407 RWHP and this brought it to 466 RWHP. I also picked up 50 ft lbs of torque at 3200 RPMs.
I also did the trunnion upgrade, added a factory Z06 air cleaner/box, and an ATI dampener. Pretty happy.
Old Apr 25, 2014 | 09:54 PM
  #67
timafey's Avatar
timafey
My friend has an 08 m6 with headers, super bee intake + tune, put out 440ish and about the same torque. (I know very high for that combination!) my bone stock. 08 z pulled on him in every gear. I had an Ls2 and I can tell you the z revs soo much faster and is very violent in 3rd gear. I'm pretty sure cammed ls3 with headers intake would be a drivers race for sure between a z.
Old Apr 26, 2014 | 09:17 AM
  #68
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Cam and the goodies that go with it. You will haul azz.
Only trouble....half the Z's are upgraded, also, but I think the power of an upgraded LS2 or 3 is easier to put to the ground, than an upgraded LS7.
Old Apr 26, 2014 | 08:45 PM
  #69
COSPEED's Avatar
COSPEED
St. Jude Donor '10
We will be offering a z spec package option very soon that will have varying levels of upgrade etc to give you the C6Z performance you want in your c6/GS! stay tuned!
Old Apr 26, 2014 | 10:48 PM
  #70
cmorales515's Avatar
cmorales515
My 1LT '08 M6 went 124 in the quarter with just bolt ons, so I won't agree that it takes a cam to get to the Z06 "level" in a straight line (and it kind of irritates me to keep reading that). Lots of stock Zs have dynoed in the 440s and trapped in the 124 range (or less). But a GS or 3LT obviously has a weight disadvantage that affects the result.
But if you define Z06 "level" as only precisely as fast as a Z06, the issue is that bolt-ons may only get you slightly less fast than a Z06, while a cam should get you a little faster than a Z06. Typical cam results should be 470-490 rwhp and high 120s in the quarter.
