05 Steering wheel replacement
Old Apr 2, 2014 | 06:37 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Default 05 Steering wheel replacement
Does anybody have instruction on how to replace the steering wheel, and what safety precautions is needed. Also do I need wheel puller, and is wheel splined.
I looked on U-Tube, and couldn't find anything, hope someone has better luck then me.
Thanks.
Save The Wave.
Old Apr 2, 2014 | 08:09 PM
RicK T's Avatar
RicK T
Here's a DIY but it's for an '06. I've seen mention here that the '05 wheel is different as far as releasing the air bag but I don't have personal knowledge.
Check this. If you look at yours and it's different you could PM member Mpuzach. He did his '05 and will be able to tell you how to release the bag.
http://forums.corvetteforum.com/c6-c...ck-spring.html
Oh, and if you're trying to change to a later wheel you need more than the new wheel, like an air bag and clock spring.
Old Apr 3, 2014 | 09:42 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
Thanks!
Also found this?????
http://www.justanswer.com/chevy/3d5m...tte-usual.html
Old Apr 4, 2014 | 02:03 PM
Justasheet's Avatar
Justasheet
Thanks.
Save The Wave.
1. Disconnect the battery and wait an hour or so.
2. I did not need a wheel puller, but had one on standby just in case.
3. Yes, the wheel is splined.
The wheel is much like the 06 and once you get the airbag off, it's pretty straight forward.
BUT
Getting the airbag off is a major PIA. There are 4 small holes behind the wheel. You must take an Allen wrench and insert it in the hole and find a spring loaded clip. When you push it in, it will release that corner of the airbag. You do this by feel. There are 4 of them.
When you do release one, pull the airbag out slightly so it doesn't pop back in. If you pull too far, it creates stress on the other clips and the spring doesn't have any give too it and you'll never find it. If you need more guidance than this, shoot me a PM and I'll give you a shout. You don't live too far away. I work in Sunrise.
Jeff
Old Apr 4, 2014 | 10:03 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
BUT
Jeff
Thanks Jeff!
To 05 Steering wheel replacement
