What diff fluid for my C6?
Old Apr 3, 2014 | 01:14 PM
Girthrockwel's Avatar
Girthrockwel
Default What diff fluid for my C6?
Id like to change my diff fluid this week and I'm not going to pay 25 bucks per quart for the dexron LS 75w 90 from the dealership. At oriely they have oils ranging from 6 bucks per quart to 20. Some synthetic some not. What are you guys using, why and how well has it worked? Thanks!
Old Apr 3, 2014 | 01:26 PM
JCtx's Avatar
JCtx
Buy the factory stuff man; it's the best, and you won't save much compared to other fluids when purchased thru a forum vendor (even with shipping). Bought mine from GM Parts House a while back, but all should have similar pricing. Good luck.
Old Apr 3, 2014 | 01:40 PM
timd38's Avatar
timd38
I have used Red Line for 15 years. I put in my 2006 Vette in 2006 an when we installed the Quaife, the inside looked like it was new.
Old Apr 3, 2014 | 03:28 PM
cclive's Avatar
cclive
How many miles on the car?
Old Apr 3, 2014 | 04:46 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I tried Royal Purple and my posi turned into a peg leg. I went back to factory fill and all is well for 76k miles and 490+ drag strip passes.
Old Apr 3, 2014 | 05:25 PM
mfoti's Avatar
mfoti
I have a 2007 that had SEVERE rear end chatter / clunk. I tried the dexron LS and it quieted it down just a little. It was still noisy and aggravating. Only 2,000 miles later I couldn't take it anymore. Based on other forum member recommendations i went with Amsoil Severe Gear 75/90 with an extra shot of slip additive. Rear end is dead quiet now. If i didn't have any problems i would have used the dexron product but it wasn't resolving the problem.
Old Apr 3, 2014 | 06:46 PM
corvettecolin's Avatar
corvettecolin
My 08 with only 21,000Km was cluncking. Changed to Redline 75-90 and added addative, all quiet now.
Old Apr 3, 2014 | 07:26 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd go with Dex, but I think Mobil1 also makes a rear diff lube/oil.
Old Apr 3, 2014 | 08:03 PM
Girthrockwel
Originally Posted by cclive
how many miles on the car?
75,000
Old Apr 3, 2014 | 09:02 PM
cclive's Avatar
cclive
Originally Posted by Girthrockwel
75,000
Fair enough! Some on here have been changing diff oil at far less mileage. I had the diff fluid changed under warranty about 5 years ago because of the grinding noise when the car was cold and I was turning sharply to back out of my driveway. They did the new Dexron LS. Silence from then on, so I have to recommend it. But if yours is not presently grinding, then you might get away with something like the Mobil One diff 75w-90 but you will probably have to add some extra friction additive.
Old Apr 3, 2014 | 09:09 PM
Girthrockwel
I've only had the car a little over a month, the fluid may be fine. I just don't know. I want to start off with a good baseline.
Old Apr 4, 2014 | 05:28 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Let's face a couple of facts: the rear diff in the C6 HAS had issues, in the past. Most have either been corrected by owners' use of their own, aftermarket fluid, or by Chevrolet's fluid such that we really don't read much about it. EXCEPT when someone doesn't know, or had done the newer-service fluid from GM, or their own.
Please don't take this wrong, but cheaping out on fluid now may not be a good thing in the long run, or even the short run. If you ask me, your baseline is now: it runs, and it's not making any noises. BUT you have some miles on it, not a garage queen with 4K miles.
If it were me, I wouldn't use Mobil 1 even tho they're at least a co. with real engineers and labs (both plural) with an "engineered" product. Some fluid, most likely from GM, has been working in your car for 75K miles. That's what I'd go with, or one of the suggested companies from above posters. But note that JoeG most likely went with his aftermarket choice based on recommendations, and then switched out of it---and I think his usage would be considered "hard service" with 490 drag strip runs.
Old Apr 4, 2014 | 05:34 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
AO Roads, you are correct. And if I recall correctly, Dennis50 who also uses his car hard had the same problem with aftermarket fill.
The diff doesn't hold much fluid so we are not talking about much money here. My recommendation is to stick to the factory fill based on experience.
Old Apr 4, 2014 | 07:28 AM
GOLD72's Avatar
GOLD72
I have used AMSOIL Severe Gear 75W90 in three vettes with outstanding results. Two of them had annoying slow speed turn chatter which was stopped with AMSOIL and the chatter has never returned. DEX LS is really good stuff but if you object to the price, AMSOIL is about half the price.
Old Apr 4, 2014 | 02:17 PM
victorf's Avatar
victorf
Road racing/auto crossing crowd expose to the harshest demands on every components on their car. With long sessions and week after weeks without a tear down. Here is one sample among many on what they say on oil:
http://forums.corvetteforum.com/auto...fferential+oil
Old Apr 4, 2014 | 02:31 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Great info.
Another tidbit of info:
I installed a trans temp and a diff temp gauge in my car back when I did a lot of road course duty at HPDEs. My factory z51 trans cooler does a great job, never above 240 or so. But my car does not have the diff cooler that the z06 does and my diff fluid would get up to 280+ after 20 minutes, which would cause me to come off the track.
For serious track duty, a diff cooler is required like the z06 has.
For street and drag racing duty, it never gets above 240, and only up to that on extended highway runs. Around town or on the drag strip the needle never registers above 140 or wherever it starts to read (I don't recall exactly where that is).
Old Apr 4, 2014 | 02:51 PM
Girthrockwel
Thanks for all of the responses guys. I think I'm going to go with the stock fluid. I found it at gmpartsdirect for $13.70 a quart. The local dealership wants $25 and change for the same thing . Besides I'm not knowledgeable enough to figure out if I need friction modifier or not with whatever aftermarket oil I might have chosen.
To What diff fluid for my C6?
Old Apr 4, 2014 | 02:56 PM
cclive's Avatar
cclive
That's a good price...you wouldn't save a ton of money by going with something else anyway...good call!
Old Apr 4, 2014 | 04:25 PM
Cherokee Nation's Avatar
Cherokee Nation
Make sure you do the figure 8's after you change it...
Old Apr 4, 2014 | 06:03 PM
1972bluelt1's Avatar
1972bluelt1
I e-mailed Mobil 1 on this subject. Their response was "use the GM stuff". I also get mine from gmpartsdirect.
