Puddle under alternator
Old May 1, 2014 | 10:49 AM
dustbusterplus's Avatar
dustbusterplus
Default Puddle under alternator
I drove the C6 to work yesterday and noticed a puddle later that evening almost directly below the alternator. It's an oily liquid thinner than motor oil and smells either of power steering fluid or coolant and is an orangey-brown color. I got underneath and saw where it blew back onto the front crossmember and back, leading me to believe it is directly in front of the crossmember where the problem/leak is.
Any ideas of where to start looking for a culprit? I'm planning to put the front on some stands and see better where it is coming from.
Old May 1, 2014 | 11:22 AM
RicK T's Avatar
RicK T
My guess is the water pump is leaking. Pretty common and happens even on low mileage cars.
The Dexcool is orange/pink in color, depending on how you view colors.
Old May 1, 2014 | 11:36 AM
2k Cobra's Avatar
2k Cobra
Old May 1, 2014 | 12:05 PM
EVRose's Avatar
EVRose
Old May 1, 2014 | 02:10 PM
dustbusterplus
If it is the water pump, is it something that needs to be tightened or an all new water pump required?
Old May 1, 2014 | 02:16 PM
DEE_Vette's Avatar
DEE_Vette
Check Motor Mounts... Liquid filled mounts might be leaking fluid...
Old May 1, 2014 | 02:54 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Those are filled with thick, black oil.
Old May 1, 2014 | 03:16 PM
Pitufina's Avatar
Pitufina
My water pump failed at 21k. So I agree that the water pump needs to be looked at. They leak through the seep hole. Meaning that the seal of the shaft failed and a new pump is in order.
Old May 2, 2014 | 08:53 AM
dustbusterplus
I looked the car over last night and it appears to have been a loose high pressure line on the power steering pump. I tightened it back down nearly two full rotations is how far it was out. I then topped off the tank and the puddle has not reappeared but it hasn't gotten a good driving yet. Thanks for you help guys.
Old May 2, 2014 | 09:47 AM
timd38's Avatar
timd38
That is great news! It's fixed! My luck is never that good.
Old May 4, 2014 | 06:46 PM
cclive's Avatar
cclive
That is lucky. I can't imagine a high pressure fitting being that loose...wow.
To Puddle under alternator
