Failed Lifter
Old May 13, 2014 | 11:33 AM
orange rush's Avatar
orange rush
Default Failed Lifter?
I just installed a new cam with new springs and push rods.
It started right up and sounded good, but after a few minutes it started to make a ticking noise. I pulled the valve covers again to check for a broken spring but found nothing. So reading up on forums, I might have to check lifter lash. The noise can be heard in the video.
Old May 13, 2014 | 11:44 AM
Unreal's Avatar
Unreal
Yep, go in and wiggle all the push rods and see if any have excessive lash. Make sure they are on the base of the cam.
Old May 13, 2014 | 12:08 PM
orange rush
Alrighty, thanks for the help.
Old May 13, 2014 | 01:18 PM
Pitufina's Avatar
Pitufina
What pushrod length did you go with? Another thing to consider is that cams will definitely make the valve train louder and headers don't help with the resonance either. Also, I would re-check the torque on those rocker arms.
However, I agree that it does sound like a sticky/failed lifter. The spring pressure may be too much for the lifter is they are really high mileage.
Old May 13, 2014 | 01:24 PM
shawnaj7731's Avatar
shawnaj7731
yup had the same thing happen to me had to install new lifters 95k miles just couldnt take the new cam and spring load.
Old May 13, 2014 | 01:54 PM
orange rush
I installed stock length push rods. 7.40 but I did not check the lash when I installed them. I just torqued them down to 22lbs and started it up.
So, if I have to change the lifters, go with LS7 type?
Old May 13, 2014 | 02:56 PM
GS_DAN's Avatar
GS_DAN
I imagine the noise is more rapid when accelerating? Same thing happened to my LS2, although a while after the cam install.
Unfortunately for me it destroyed my cam in the process. LS7 Lifters seem to be the way to go.
Old May 13, 2014 | 03:01 PM
orange rush
I haven't driven it much, maybe 5 miles since starting it up. What is odd about it, when first started up and the oil is cold the ticking is not there, but once the oil heats up then then it starts.
So hoping the cam is not bad since I only drove a few miles.
Old May 13, 2014 | 03:45 PM
Unreal's Avatar
Unreal
Cam probably is wiped already if the lifter is bad/etc. If you didn't check preload that could be a major issue too. That is step 1. You never just put in pushrods, always measure.
Old May 13, 2014 | 06:32 PM
orange rush
After bring the piston to TDC and bringing the rocker to 0 lash, then torquing to 22lbs, should I still be able to turn the push rod? Because so far, following the instructions, I can get 0 lash, turn 1/2 and get 22 lbs and still roll the push rods between my fingers.
Old May 13, 2014 | 08:14 PM
Unreal's Avatar
Unreal
Nope, pushrod should be tight and have .06-.08" preload once torqued. Sounds like rods are too short.
Old May 13, 2014 | 08:17 PM
orange rush
So maybe a smaller base circle on the cam?
Unreal, its unreal your knowledge of these cars. lol thanks for all the help
Old May 13, 2014 | 11:21 PM
Unreal's Avatar
Unreal
Aftermarket cams typically have smaller base circles so that is somewhat common. Just get a push rod checker, or you can do the bolt turn preload method. Should have a solid 1.5 turns of preload from zero lash until bolt torques.
Old May 14, 2014 | 08:48 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
I say p-rods are too short too. Not something you'll really notice til you start it. You'll end up over-tightening everything to make up the difference and put undue stress on everything. It'll run fine for a while, but you'd likely break a spring or collapse a lifter as a result. Get a $20 pushrod length tool and know for sure.
Btw...LS7 lifters are the standard now. It's the same part # across all LS engines these days. LS3, LS9, LS7...all the same lifters.
If you're swapping lifters, Brian Tooley SLR's are the standard replacement upgrade unless you're switching to link bar lifters.
Old May 14, 2014 | 09:07 AM
orange rush
Going to research this more today before moving ahead and contacting the vendor again. The car starts up and runs fine however. But agreed, more problems in the future if I dont address this now. However, I have been thinking about the oil in the engine. I replaced with filter and oil before starting the car with Mobile 5w30 as usual. The lifter does not start ticking until the oil gets to about 120 degrees. Start up and idle initially the car has that sewing machine sound that is expected. So maybe I should move to 10w40?
Anywho, started my parts list for the lifter swap.....
Old May 14, 2014 | 12:00 PM
mfoti's Avatar
mfoti
When did GM start using LS7 lifters? Do any LS2's use those lifters?
Old May 14, 2014 | 12:16 PM
07_C6_WPB's Avatar
07_C6_WPB
My lifter went and took out my cam.. Metal shavings everywhere. I yanked the whole motor.
To Failed Lifter
Old May 14, 2014 | 02:54 PM
orange rush
Found this while searching the net...
A 228R cam has a base circle radius of .7265". That means the 228R cam has a .049" shorter base circle radius than the stock cam. If you are trying to maintain stock lifter preload with the 228R cam, you will need to run a .049" longer pushrod than stock .7755"-.7265"). Adding .049" to the stock 7.38" pushrod length gives you a 7.429" pushrod. The 7.425" pushrod comes closest to maintaining factory preload with the 228R cam. If you run a 7.400" pushrod, it will work, but you will be running .029" shallower preload than stock.
Old May 19, 2014 | 08:40 AM
orange rush
Another question for you all.
I got an pushrod length checker and got around to checking it over the weekend.
I started off with the rod set at 7.40 or stock, and it took 1/2 turn to get to 22 lbs torque. I then gave the pushrod checker one full turn, that should equal .50 more in length, and torqued it again, got one full turn of the socket before hitting 22 lbs. So I am assuming then that I will need 7.425 long pushrods.
That being said, to you all think that will quiet the engine down? Of should I move ahead with lifters?
Old May 23, 2014 | 11:49 AM
orange rush
Looks like it will be lifters after all. Installed 7.425 pushrods, and 10w40 oil. It started right up and idled nicely until the oil temp hit 180 then it started rattling again.
So ordered LS7 lifters, new trays, head gaskets and valve cover gaskets. Hoping like hell this fixes it and I can start driving it again soon.
