Failed Lifter
Old Jun 10, 2014 | 11:43 AM
  #61
COSPEED's Avatar
COSPEED
St. Jude Donor '10
What works on paper hardly ever works when applied in this instance.
I know ive tested it extensively.
Old Jun 10, 2014 | 11:57 AM
  #62
nbm6spd's Avatar
nbm6spd
Default Oh
When I design and build things I notice the paper and product parallel one another. That's just how it is supposed to be and how it works.
Old Jun 10, 2014 | 02:14 PM
  #63
COSPEED's Avatar
COSPEED
St. Jude Donor '10
If that were right then like I said all you need to do is measure the new base circle. Nothing else needed.
If you actually did a measurement with a dial indicator you would see that the cup movement inside the lifter is not linear. So where does your math compensate for that? I have measured high mileage lifters, brand new lifters, 40-50k lifters. They are not exactly linear. Just like the difference in turning torque vs breakaway torque.
Old Jan 11, 2015 | 08:35 AM
  #64
Whis9's Avatar
Whis9
Great info in thread
Old Jan 13, 2015 | 08:55 AM
  #65
nullpointer's Avatar
nullpointer
Doesn't the morels require less preload than LS7s?
