Brake fluid question
Old Jul 9, 2014 | 10:34 PM
cpetruzzi's Avatar
cpetruzzi
Default Brake fluid question
I bought my beautiful '08 M6 Z-51 dream car a couple of weeks ago and I'm starting to do some basic maintenance. The clutch fluid was pretty black so I started the Ranger fluid change procedure and that's working fine. I also noticed that the brake fluid is much darker than normal. The car only has 17k miles and I thought that was unusual. Does anyone know what causes this? I guess I need to bleed the brake system and get fresh fluid in there.
Old Jul 9, 2014 | 10:42 PM
RicK T's Avatar
RicK T
The brake fluid should be changed every 2 years. That is recommended by car enthusiasts, not by GM.
I'm sure you know it's hydroscopic and darkens with age so miles don't mean that much, but could be a factor.
Old Jul 10, 2014 | 12:59 PM
mikeCsix's Avatar
mikeCsix
If it were my car, I would change all of the fluids and have the engine coolant tested for acidity or just flushed and changed, whatever is easier for you. That way you have a baseline to work with.
Old Jul 10, 2014 | 02:59 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
BLACK BRAKE FLUID; I have been doing a lot of reading on the subject and so far have not found a definitive answer...just a lot of opinions. I always thought it was moisture contamination and/or heat but haven't been able to prove it on the work bench. The clutch fluid turns do to clutch dust contamination.
Bottom line; keep an eye on the color of both brake and clutch fluid and change it out when it turns amber (cannot see through it)....do not wait for it to turn black!
Old Jul 10, 2014 | 03:42 PM
cpetruzzi's Avatar
cpetruzzi
Default Good plan
That's a great idea. Thanks.
Old Jul 11, 2014 | 08:22 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I echo both Rick and mike esp. since you probably don't know if the rad/coolant has been changed and it has a change cycle of 5 yrs/100K or 150K miles whichever comes first. And time in years has already come and gone.
To Brake fluid question
