alignment facility in connecticut
Old Aug 7, 2014 | 08:45 PM
BJ67's Avatar
BJ67
Default alignment facility in connecticut
Great mechanical shop in windsor Connecticut, dayhill automotive. they have a laser hunter machine, a great tech that works the machine and are reasonable. I had my 08 z06 aligned, they will set to your specs or the newest chevy specs. The owner of the shop is a road racer (ford guy) and I am sure if you track the car they will set it up the way you want. My car I wanted the rear to be 0 toe and close to 0 on camber as possible for drag purposes, front specs were set with a little less neg camber very little toe and caster with in the factory spec. I cost me $98.00
