Retune after roller rocker install.
Old Jan 11, 2015 | 06:56 PM
shawnaj7731's Avatar
shawnaj7731
Default Retune after roller rocker install.
I have a quick question, do you need to retune after going from stock 1.7 rockers to comps 1.72 roller rockers, also the push rod went from 7.5 to 7.550 . This is a H/C/I/E ls2 that had already been previously tune and set. I am just curious is all.
Old Jan 13, 2015 | 04:55 PM
CHJ In Virginia's Avatar
CHJ In Virginia
IMHO You have not really changed any of the operating conditions on the engine by changing the rockers. I would not waste the $ on a retune.
Old Jan 13, 2015 | 05:42 PM
timd38's Avatar
timd38
I wouldn't.
Old Jan 14, 2015 | 02:17 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
If the only thing you did was change from a 1.7 to a 1.72 all the valve change was 0.007" lift at the valve and a very ever so slight amount of duration.
I wouldn't worry about it.
If it was as big of a change as a 1.5 to a 1.8...then yes I would get it checked out.
To Retune after roller rocker install.
