2 in kooks headers question
Old Jan 23, 2015 | 03:41 PM
curtisb23's Avatar
curtisb23
Default 2 in kooks headers question
I was just wondering if it would benefit my all motor nitrous car from going from 1 7/8 kooks to there 2in ? And one ever do the switch
Old Jan 23, 2015 | 03:58 PM
timd38's Avatar
timd38
Have you talked to Kook?
Old Jan 23, 2015 | 04:08 PM
curtisb23's Avatar
curtisb23
No I haven't, I'm kinda new to the vettes ,I already have the 1 7/8 car made 470whp just put a nitrous kit on it and was just wondering, money isn't a issue
Old Jan 23, 2015 | 04:13 PM
curtisb23's Avatar
curtisb23
Didn't really find much on here but people going back an forth
Old Jan 23, 2015 | 04:27 PM
timd38's Avatar
timd38
You typically lose bottom end with bigger headers. You not putting out enough power to need 2". Just my opinion
Take a look at this article.
http://www.superchevy.com/how-to/491...ower-increase/
Old Jan 23, 2015 | 04:30 PM
JDP Tech's Avatar
0JDP Tech
Former Vendor
1-7/8" are good up until about 800 RWHP, after that I suggest going 2". In reality, the ports in your heads are only so big and you'll lose velocity at lower RPM. You may gain a touch more peak HP, but low end will suffer; basically you'll just be shifting the powerband upward in the RPM range. So unless it's a very serious build, 1-7/8" will suit you best.
Feel free to call, PM or email us anytime with questions.
Best regards,
Tyler
888-308-6007
Old Jan 23, 2015 | 04:49 PM
dennis50nj's Avatar
dennis50nj
Your losing power with the 1 7/8 the power from the nitrous will push out the tubes , go back to 1 3/4 you will have more power under the curve the gain is at 7000 rpm for the bigger tubes
Old Jan 23, 2015 | 04:57 PM
curtisb23's Avatar
curtisb23
mm I don't believe that .my car made great power on stock intake manifold witch was 450/400 then added a fast 102 that was ported and max injectors out and am 470whp/423tq
Old Jan 23, 2015 | 04:58 PM
curtisb23's Avatar
curtisb23
also with headers xpipe no catts ,corsa back ,vararam intake and a comp cam
Old Jan 23, 2015 | 05:00 PM
curtisb23's Avatar
curtisb23
Best regards,
Tyler
888-308-6007
thanks for the input, car is staying stock bottom end and stock heads for now, just full bolt on and a 150 shot
Old Jan 23, 2015 | 05:05 PM
dennis50nj's Avatar
dennis50nj
This is a real dyno number and I have the timeslips to back it up. 1 3/4 vs 1 7/8
Old Jan 23, 2015 | 05:10 PM
curtisb23's Avatar
curtisb23
what kind of motor are you refuring to ? what are these times you speak of? I have some great time slips with 450whp
Old Jan 23, 2015 | 05:23 PM
timd38's Avatar
timd38
Sorry how doe we know the 1 3/4" from 1 7/8" on the chart?
Thanks!
Old Jan 23, 2015 | 05:24 PM
JDP Tech's Avatar
0JDP Tech
Former Vendor
For anything under 450 WHP, I agree that 1-3/4" is the way to go, but at the OP's power range with the 150 shot, 1-7/8" are the way to go.
Best regards,
Tyler
888-308-6007
Old Jan 23, 2015 | 05:33 PM
dennis50nj's Avatar
dennis50nj
Thanks!
Look at the the tq drop with the 1 7/8 then the tune we got a couple more 492 you can see the power gain was only at the highest rpm, dyno 64 65 1 3/4 dyno 67 68 1 7/8 dyno 66 doesn't show as just driving to let maff adjust
Old Jan 23, 2015 | 05:35 PM
dennis50nj's Avatar
dennis50nj
LS2 NA
Old Jan 23, 2015 | 05:38 PM
timd38's Avatar
timd38
I did 1 3/4" for better torque, but never had dyno numbers to validate, so thank you!
To 2 in kooks headers question
Old Jan 23, 2015 | 05:39 PM
curtisb23's Avatar
curtisb23
is this a stock head and bottom end motor? ,my motor only has a cam an kit everything else is stock motor
dennis50nj's Avatar
dennis50nj
Best regards,
Tyler
888-308-6007
I disagree for anything under 383 CI I tested a number of tube sizes and manufactures, try to get the extra et
Old Jan 23, 2015 | 05:42 PM
dennis50nj's Avatar
dennis50nj
stock bottom end stock rod bolts 243 ported heads with serdi valve job stock valves, fast 90 what did you run?
