Ported TB
Old Feb 21, 2015 | 11:11 PM
05Z51C6's Avatar
05Z51C6
Default Ported TB
Considering adding a ported TB to my current mods. If only adding the throttle body, do you typically tune (or re-tune in my case)?
Old Feb 22, 2015 | 11:33 AM
Dano523's Avatar
Dano523
Depends, is the TB the choke point in the turbulence, or is the intake manifold the turbulence choke point instead?
If you have a OEM LS-2 intake manifold, that it's the nightmare in the math of why the motor can not breath at higher RPM's, until its Turbulence problems are resolved, then little will a ported TB resolve in the grander scheme of things.
Also, are you running open loop, or close loop?
Old Feb 22, 2015 | 11:43 AM
TTZ06VETTE's Avatar
TTZ06VETTE
If you use the same size TB, most of the CNC ported throttle bodies do not require a retune. Depending on how aggressive the hand ported throttle bodies are you may need to adjust the idle airflow tables a bit. At the end of the day I had more problems with my hand ported TB throwing codes. My CNC unit although less aggressive has been fine requiring no additional tuning.
Old Feb 22, 2015 | 03:56 PM
05Z51C6's Avatar
05Z51C6
I have a fast 102.
I am looking at one of the vmax cnc ported units.
Old Feb 22, 2015 | 05:48 PM
tennblkc6's Avatar
tennblkc6
Originally Posted by 05Z51C6
I have a fast 102.
I gather you have a tune for the fast 102. you may be ok with the ported tb. I also have the 102 and ported tb but I have a tune.
Old Feb 22, 2015 | 08:37 PM
schizcat's Avatar
schizcat
If you currently have a tune, I would ask your tuner. A reputable tuner will give you straight up advice and not look to make extra $$. I have heard from most tuners (in person or on the forum) that it is not needed. Also, if you do have a reputable tuner, they may retune for a small cost if needed.
I will add that I do have a ported TB and have not gotten a tune because of it. The TB will increase your throttle response which will mostly be seen on the track.
Old Feb 22, 2015 | 09:23 PM
Sativa's Avatar
Sativa
I added a vmax cnc ported throttle body to my already tuned LS3 and it runs great.
I didn't get it re-tuned after the install.
To Ported TB
