Does standard LS3 need an oil catch can?
Old Feb 26, 2015 | 10:25 AM
Dark Knight's Avatar
Dark Knight
Default Does standard LS3 need an oil catch can?
Please forgive my ignorance but, does a standard LS3 need an aftermarket oil catch can? I have read several threads re: the installation of an oil catch can but most appear to be written by members who either have the dry sump system or they track their cars placing more stress on the engine. Does a street driven LS3 need this modification? I am confused.
Old Feb 26, 2015 | 05:41 PM
Cherokee Nation's Avatar
Cherokee Nation
I have one on my 08/Z51 and I do not drive it much every day.Every time i drain it i get about a oz of oil out of it.Do a search and you will find a lot of information about them.No harm with adding one to your vette...
Old Feb 26, 2015 | 05:50 PM
Dark Knight
Thanks. So far you are the only member to respond.
Old Feb 26, 2015 | 05:53 PM
KB9GKC's Avatar
KB9GKC
Hello,
Don't bother unless you are going to track your car!
Enjoy the LS3, GM did a great job.
Douglas in Green Bay
Old Feb 26, 2015 | 07:25 PM
C6z06man's Avatar
C6z06man
Won't be worth the money unless tracked or highly modified. Spend the money on gas and just drive!!
Old Feb 27, 2015 | 10:44 AM
Cherokee Nation
I have never tracked my vette,just a short cruze every day at 45mph.I do get on it at times to clean the engine out.....Like said, I get about a shot glass of oil out of the can when I change the oil between 4-5000 miles.....GM builds crap...
Old Feb 27, 2015 | 02:27 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Typically it is not needed, but it isn't a bad idea either.
The way they have the car setup from the factory is that any and all bypass products have to back through the engine and get burned and processed by the cats. This includes any blow by and oil/oil vapor. By installing the catch can you reduce (or remove in some cases) any oil going back through your engine. This can cut down on build up on the valves, in the chambers and reduces the chance of ignition knock.
You do have to keep an eye on it, and drain it from time to time as there is no place for it to go, other than into the can. Depending on how you drive, and how much wear is on the engine...how much oil it is going to produce in the can.
Old Mar 1, 2015 | 10:44 AM
Dark Knight
Thanks everyone. your responses have reinforced what I believed to be a logical answer to this question. A street driven, naturally aspirated, LS3 does not require an aftermarket oil catch can. Installing one is fine for those who feel better having it. Dark Knight
To Does standard LS3 need an oil catch can?
