Please explain if there is a mistake so I can relay it for correction.
Care to share?
Sure 275x40x17 373 gears a4 3800 pa converter cross at 7000-7100 in third at 131-132 mph single disk not tuned or set to lock at wide open throttle weight 3260
Did you try putting in 7% converter slip since you don't lock yours up as the numbers are then spot on not accounting for any tire growth though, which is maybe what Gary is talking about...
no i dont think i have any slippage at that rpm because it couples quickly, im not a converter expert and locking in third wouldnt give me that much more mph or lower the rpm that much, the reason i never used the nitrous at the track dont have a built trans to shift into 4th and that still isnt a good idea if it was
I wouldn't recommend shifting to 4th on the juice either, no matter how good the efficiency of a converter as everyone is going to have some. It's like prop slip on a boat if you do any fishing, my other hobby That calculation is an indication of yours like I said w/o taking into account of tire growth which shouldn't be more than an inch overall at that speed on a radial with only 4.25" of sidewall IMO, but should remember the last 66' is an average mph for the trap speed so you'll actually going slightly faster when crossing the stripe at the end than what prints out on the slip. I like to think the small amount of tire growth offsets that.
Hey Dennis.....
On your PB run, what was your
mph
rpm at the stripe
gear
tire size (radial or bias)
Care to share?
I chose the TR6060 for my car and inputted the values. The resultant rpm was higher using their calculator versus mine. Transmission gear ratios are correct so I assume there is an issue in the actual calculations.
