I've seen multiple posts about certain wireless npp controllers not working in newer vettes. What model will work with a 12' I guess it has to be compatible with the home link?
I cannot speak to a wireless unit but I put a jumper switch in the ash tray for mine, I think it's easier than trying to mess with a remote while I am driving.
Just wire up a old school foot switch in the dead pedal. Kind of like the days gone by headlight dimmer switch. I never have grasped the idea of fumbling around with a remote, also something else to loose.
To your point, I do not recall the remote style not working with a remote switch in newer cars.
No matter how fancy the NPP controller is, all it doing is either letting current through the NPP fuse location or not (same as you pulling the fuse, or plugging it back in).
If you want the type that have the remotes, then here, but will still need to add a circuit, a barrel connector, crimp on male space and round wire connector as well.
Red wire goes to the add a circut with the barrel connector to pull power to the unit from the seat heater fuse bank,
White wire plugs back in at the NPP fuse location on the left hand side with a male spade connector, without a fuse in that location.
Black wire gets connect ground with a crimp on round connector.
Second photo from the bottom, which will start the car with the NPP off (like you pulled the fuse), and you just press the remote switch to put the NPP system back in normal mode instead. http://www.parts123.com/corvettecentral/pdf/326086.pdf
As for mating the visor buttons to the remote to use the visor buttons, not going to work, since the car-2-u programing in the visor control is not comparable with the remotes (not just this system, but many others as well.)
Note, the old home like units did not have this problem in the older cars.
