Cant help with your problem but what gaps are you running??? The group picture looks way wide and the single plug pictures look really tight, maybe camera angle??
NSF
The top pics are after 40k miles and the gap opened up to about .065. The bottom pics (new plugs) are gapped at about .048. It's just the camera angle.
To test the injector, couldn't he just swap injectors and see if spark plug discoloration follows? Say switch #3 to #2 and see if plug 2 starts to display the darker coloring.
if your going to take it to a shop or have access to a gm tech2 take a look at your coils. recently had issues on my silverado with the 5.3l. wasnt throwing codes but i had a coil going bad in it(which could cause a rich condition in that cylinder). it occasionally had a ruff idle and got worse over time. you didnt mention the year of the car. but i recently replaced the the coils in my 05 (for looks only) and the old ones were the same p.n. as the ones in the 07 silverado. so it didnt cost me anything to get it fixed, since i never throw out good parts. it is just a suggestion to go with.
From: The only state to ever kick another country's ass! TEXAS
Absolutely. What's throwing everything off is the noise which admittedly could be unrelated, but might not be. That's why I recommended the compression and leakdown tests first. They are probably the easiest things to do, and will eliminate some possibilities. Swapping injectors would be a good second step since the plugs and wires have already been replaced.
I'm honestly not sure. I've seen it done before when a tuner couldn't figure out what was actually wrong. It was easier to just disable the codes than to figure out why it was misfiring.
I **think** it's more common on larger cam'd cars.
Not saying that's necessarily what's been done to yours. just throwing out information hoping something helps
Originally Posted by tennblkc6
I've read that they are sometimes disabled due to aftermarket stall converters. not sure if this is true or why...but I have read this.
My car is a manual and the cam is fairly mild. But I will be sure to inquire about this to the tuner.
I finally got a chance to drop the car off at my tuner. The leak-down test was perfect but a compression test showed a little high on cyclinder 3. None of the springs are broken. My tuner seems to think it's a spun lifter so the heads are coming off next and we'll see what the extent of the damage is and go from there.
Any ideas how bad things could be? What have you guys seen in regards to damage in these situations? Think it started eating the cam?
Sounds like your tuner maybe on to something, my guess is with the exhaust valve not opening enough, due to a scored lifter roller and/or wiped cam lobe. Also the exhaust valve could be sitting to high (closed position) in the combustion camber, inhibiting the flow of spent exhaust, hence the sooted #3 spark plug (incomplete combustion of fuel).
FYI, engine would be very hard to keep running with a broken valve spring.
Keep us updated.
GL
Couldn't you see valve lift with removing the valve cover?
If you are referring to my post, yes you can see that the valve is actuating, but it would be hard to evaluate how much lift and the duration by just eyeballing it.
My thinking is that if the lob and/or the roller is damaged, that the limited duration and lift will influence the exhaust scavenging from the combustion camber, hence the black sooty spark plug.
This may also support the theory of higher compression of just the #3 cylinder.
I just got off the phone with my tuner. It looks like the roller on the lifter started eating away at the cam lobe. He believes it was from a weak spring causing the lifter to slam down on the cam during a high RPM run. Supposedly my intake valve was barely opening. So now they're pulling the motor to check the bearings, crank, and cylinder walls hoping all those metal shavings didn't destroy everything. I should know by the end of the week. Isn't this a fun hobby...
I've seen plenty of roller cams wipe out, just like the old flat tappet types that was used in the past.
This can happen sometimes for no apparent reason.
Good luck, hopefully there is not extra damage to the engine.
