I got around to changing out my plugs and I'd like your help reading them. This is what they look like after about 40k miles(I know too long). Anything I should be concerned about? Pay particular attention to plug #3.
Sorry the lighting looked better in the garage.
Now this is new plug #3 after maybe a couple hundred miles.
While the rest look similar to this.
Coincidentally, or maybe not, the noise I have been chasing which I assumed was an exhaust leak, is most noticeable right around plug #3.
2007 LS2 with H/C/FAST, NGK TR55s .048ish and slightly bumped CR. Always ran on 93.
So talk to me. What do you think is going on and what do I need to be worried about? The car runs great and no codes are stored or being thrown.
One of my posts from the exhaust leak thread.
Originally Posted by 5knives
Any update on this? It sounds very similar to what I have been experiencing. My sound is on the front driver's side and only during throttle. If I put the trans in neutral while rolling the sound is not present until I step on the throttle. In gear it is only present while accelerating as well. There is also no rhythm to the sound. This leads me to believe it is an exhaust leak. If there was something in the tire/wheel it would only make the sound during a revolution and you would almost be able to time the beat as you memorize the rate of rotation. Valvetrain noises also have somewhat of a rhythm as well since everything moves in unison. This sound just seems to be sporadic. My header bolts feel tight and so do the connections down stream so I would have to assume it's the header gasket?
From: The only state to ever kick another country's ass! TEXAS
It's really hard to tell from the pics. Looks like you might have a valve stem seal leaking a little or an injector. Hard to tell if it's oil or not. Probably not blowby since it's only one plug. How many miles are on the car?
56k on the car and about 40k on the plugs in the top pic. The pics of the single plugs are only about 100 miles or so. Do you think this could be contributing to the noise or vise versa?
Hard to tell if the black deposits on #3 plug is "dry" or "wet". If the deposits are "dry" you're getting too much fuel, if they are "wet" then you have a problem with oil getting into the cylinder.
Just guessing, I would say the noise is unrelated, unless you are getting a ping in that cylinder from oil in the combustion chamber. You really don't have that many miles on the car. I would guess a valve stem seal, but that's just a guess. That plug looks wet to me, all the way to the seat. Is it wet or dry?
Obviously something isn't right. I would probably start with a compression check and a leakdown test just to verify everything. They are relatively easy, and will keep you from chasing your tail.
The plug is wet. I'm hearing a noise which I assumed was an exhaust leak up until now. After seeing this I have to assume it's a misfire/ping from oil in the chamber? But I'm still not getting any codes. I'm guessing I have to bring it to a shop for a compression/leakdown test?
You should check exhaust manifold bolts see if they are all tight cause a couple of loose bolts will cause a leak and in turn the ECM will read one bank leaner than the other adding or taking fuel, I seen as much as 10% leaner on one bank than the other as a result.
As for your spark plugs install new ones and run them for 500 miles then check the new plugs instead.
I just replaced the exhaust manifold gaskets because I thought maybe they were leaking but the noise remained. The bolts should be good but I don't know if there is still a leak somewhere. With a stethoscope the noise is most noticeable on cyclinder #3.
The plugs are brand new, maybe 100+ miles on them. (Not the top pic)
So I pulled the plug again, the car hadn't been driven since the picture, and the plug is dry now. Whatever was on there evaporated (gas vs oil?) I started the car and let it run for about a minute. Then I revved it up until I heard the noise and let it sit there for a few seconds. I did this a few times then shut it down and pulled the plug again. It's still dry and almost looks as if it was cleaned off slightly. It's cleaner than in the original picture but not like the others. I'm sure if I was out for a longer drive the plug would get wet and dark again. Does any of that information help?
I would say if the plug is dry and doesn't have an oil residue on it, more than likely you have a leaky injector, but the noise you are hearing is throwing me off. Is it a metallic sound and does it speed up and slow down with rpm? Can you hear it at the exhaust tip?
I didn't try listening at the exhaust tips. It's really only noticeable on the driver's side near the exhaust manifold/head and only upon acceleration. At idle the sound isn't there. If I start to give it gas, around 2k rpms, it'll start and get a little louder as I accelerate until it is either drowned out by the rest of the exhaust noise or it disappears. Hard to tell exactly because it's so noisy. But it doesn't speed up or slow down with throttle input, it only gets a little louder or softer. And it has no steady rythem to it. I listened to some sound clips of broken valve springs and it doesn't sound like that. It doesn't sound metallic or like a clunking or steady tick. That's what originally led me to think maybe it was an exhaust leak. But I find it hard to believe it's a coincidence the sound is right near where I have a questionable plug. Perhaps I'm hearing misfires from that plug but there are no codes being thrown or stored. The car drives fine. No smoke, stumbling, hesitation, etc.
It could be the catalytic converter rattling, but it's impossible to say. I would do a compression check and leakdown test if you have the tools and ability. If not, I would take it to someone. I'd love to help more, but I just can't offer much without seeing and hearing in person.
Understood and I appreciate the help thus far. The plan is of course to take it to my tuner for an accurate diagnosis but that won't be for a few weeks. Plus I like knowing what's going on before hand so I can decide how worried I need to be. I'm just going to keep an ear on when driving to see if the symptoms change any or if there are more distinguishable characteristics to help narrow it down.
The fact there is no misfire or negative impact on driving performance is throwing me off.
That's a good thing. Even if the noise is exhaust related, it shouldn't contribute to the spark plug condition though. That's why I suggested the compression and leakdown tests. I still think the plug looks like the #3 injector is leaking if that's not oil on it. That would be an easy and relatively inexpensive fix also.
Ticking noise could be bad plug wire or bad boot making plug look like burning rich
The wires are brand new Acdelcos and the sound was there before and after so I don't think it's that. The sound is more like a crackling than a steady tick.
Cant help with your problem but what gaps are you running??? The group picture looks way wide and the single plug pictures look really tight, maybe camera angle??
NSF
