devil wipers
Old Dec 7, 2015 | 11:15 AM
otays's Avatar
otays
2nd Gear
Default devil wipers
I have a 2000. Wipers come on when you start the car and won't shut off. I've taken it to two chevy houses. They had it 4 months, $3200.00 (switched out computers) and they can't fix problem. I'm amazed a chevy dealer can't fix this kind of problem. Any ideas?
Old Dec 7, 2015 | 11:54 AM
EVRose's Avatar
EVRose
Maybe should post this in the C5 forum but if it were me I'd change the wiper control lever. I hope you didn't have to pay that $3200 if it did not fix the problem.
Old Dec 9, 2015 | 10:05 PM
crusher1's Avatar
crusher1
This may help
https://www.corvetteforum.com/forums...on-t-stop.html
Old Dec 13, 2015 | 02:07 PM
fevest's Avatar
fevest
washer switch messed up. I would want my money back. simple fix, even without changing stalk. I had a c5 that did this. You are probably out of washer fluid also. Use a little electronic screwdriver and pop out the washer button. you will see contacts. for a test, put a piece of plastic or something between the contacts and see if that fixes it.
To devil wipers
