FAST Intake
Old Dec 22, 2015 | 11:11 PM
Murdered07's Avatar
Murdered07
Default FAST Intake
I have a deal on a fast 90 intake and I think I remember a forum saying there may be trimming involved to fit? I can't find that thread again but does anything need to be done to fit that intake? I have a stock throttle body if that plays a factor
Old Dec 23, 2015 | 09:58 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
What year motor/car are you putting it on?
I believe 90's were all for cathedral ports heads.
Old Dec 23, 2015 | 12:46 PM
Murdered07's Avatar
Murdered07
It would go on a 2007 z51
Old Dec 23, 2015 | 12:56 PM
timd38's Avatar
timd38
What year is the intake? early ones had a fit issue. The did not clear the firewall.
Old Dec 23, 2015 | 01:50 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Why?
Old Dec 23, 2015 | 02:30 PM
timd38's Avatar
timd38
Originally Posted by schpenxel
Why?
If you look at a new FAST the back is lower than the front. Early ones required cutting the cowl up. I did a forum search but I could not find it. Below is an article I find using google.
http://www.superchevy.com/how-to/vem...take-manifold/
Old Dec 27, 2015 | 09:19 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Here's the thread. You can cut the FAST and put in a patch instead of cutting the car if you like. But don't use plastic, it will melt and you will have a huge vacuum leak. My buddy fashioned a sheetmetal patch for me and glued it in with epoxy 5 years ago and it's been fine ever since.
https://www.corvetteforum.com/forums...t-install.html
Old Dec 27, 2015 | 11:04 AM
Brandon619's Avatar
Brandon619
Interesting Joe, I just installed a FAST yesterday on my 05 C6 and the back of the manifold is really tight on the back of the cowl/firewall.
Old Dec 27, 2015 | 11:12 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
FAST 92 or FAST 90? The 92 was modded when it came out to fit the C6.
Either FAST is a GREAT mod for the ls1, 6 or 2. Particularly the LS2, you did well installing one.
Old Dec 27, 2015 | 11:28 AM
Brandon619's Avatar
Brandon619
Mine was a 102.
To FAST Intake
