Reduced Engine Power...
Old Jan 28, 2016 | 05:51 PM
  #61
Spoolin8's Avatar
Spoolin8
Update: Replaced the pigtail and that didnt fix it. Its getting a new ECU next week. Car has been sitting this week and I noticed by clock is off by 8 mins. I have an aftermarket radio but isnt the clock being off a potentially sign of a bad battery cell?
I wonder if Autozone would let me just plug in a brand new one so I could rev the engine and see what happens....
Old Jan 28, 2016 | 07:28 PM
  #62
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Buy one off amazon and send it back if it doesn't help
Old Jan 28, 2016 | 07:34 PM
  #63
extrapilot's Avatar
extrapilot
Have Autozone due a load test on the battery. It will certainly show a bad cell right a way.
Old Jan 28, 2016 | 08:59 PM
  #64
Spoolin8's Avatar
Spoolin8
When i check it with a multi meter everything checks out but im assuming they have a better form of testing them?
Old Jan 28, 2016 | 09:15 PM
  #65
extrapilot's Avatar
extrapilot
Got to have the load test done, as it will simulated a high drain on the battery like when you start the car, which the starter will be the highest drain that it will see.
While the load is applied, the battery voltage will be displayed, indicating the true strength.
If only one cell is bad, the voltage will drop like a lead balloon.
Old Feb 12, 2016 | 01:38 PM
  #66
Spoolin8's Avatar
Spoolin8
Just got word that swapping the PCM did not fix the problem. Another $700 sunk into it and no closer. Im going to replace the battery tonight because why not...
Old Feb 12, 2016 | 05:49 PM
  #67
Spoolin8's Avatar
Spoolin8
Battery tested out to be fine. What is interesting though is that since switching the PCM, I have noticed that the vehicle starts easier and has a better idle.
I also only throw one code now, 1516.
The 2101 code appears to have resolved...
Old Feb 15, 2016 | 10:55 AM
  #68
Spoolin8's Avatar
Spoolin8
After having the new PCM for a day the problem now occurs all the time. Car will start fine and then approx 30-60 seconds into idling it goes into reduced power. Have an excellent shop working on the car now and they plan on looking at the harmonic balancer work and checking the grounds near there since it was the last thing that was changed before this problem.
Old Feb 15, 2016 | 11:27 AM
  #69
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That is incredibly weird.. I really just want to know what it is at this point. I think they're going in the right direction by looking over the balancer install first
Old Feb 15, 2016 | 12:10 PM
  #70
Spoolin8's Avatar
Spoolin8
Once they get the car up if it turns out to be a loose clip/harness by the balancer, half of me is going to ecstatic and the other half is going to be furious.
Old Feb 15, 2016 | 12:27 PM
  #71
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I was thinking the same thing...
Old Feb 15, 2016 | 12:37 PM
  #72
Spoolin8's Avatar
Spoolin8
The first shop that did the install is very well known and has done great work in the past. I have been giving them the benefit of the doubt with the original work but if it turns out to be a poor install im going to have a conversation...
Old Feb 15, 2016 | 01:50 PM
  #73
jatolbert's Avatar
jatolbert
I have not read through this entire post but I wanted to share a little info with you. I had the exact same problem and codes. Replaced throttle position sensor, throttle body, pedal, etc. I was pulling my hair out. On the advice of Zip Corvettes, I flashed the ECM back to stock and re-tuned the car and the problem never happened again. Its been several years ago but we did figure out what in the tune was the likely issue but I can't recall exactly what it was.
Just a thought. Wish I would have known that earlier. Best of luck.
Josh
Old Feb 15, 2016 | 02:34 PM
  #74
Spoolin8's Avatar
Spoolin8
I replaced the PCM and had it re-flashed. Loaded the previous tune and same problem at first but now its manifested into it happening all the time. With a brand new PCM it seems like this is something related to a ground.
Old Feb 15, 2016 | 03:02 PM
  #75
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
You can't just re-load your tune. If the problem is in the tune you just reinstalled it into the new PCM. Here is a thought, Reflash your new PCM.
Take your fuel maps, air maps and timing tables and reload those onto a new tune. Flash that into the car and see how it does.
Also do you have any stereo cables or amp cables running close to the throttle pedal.
Old Feb 15, 2016 | 03:06 PM
  #76
jatolbert's Avatar
jatolbert
Justin is who recommended my flash that fixed my problem. If you reload the same tune, you defeat the purpose.
Josh
Old Feb 15, 2016 | 04:22 PM
  #77
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Reflashed as in by GM to get it setup for your car OR by another company with HPTuners/EFI Live/etc.?
To Reduced Engine Power...
Old Feb 15, 2016 | 06:47 PM
  #78
Spoolin8's Avatar
Spoolin8
They had a GM guy come in, install a new PCM, and reflash to make sure it matched my VIN, etc. They looked over the speed density tune (everything looked normal) and put it back on there with the same result which obviously could point to the tune being the problem. However, the following day it started occurring all the time so we are getting a different result.
I can pay them to just can the current tune and do their own, but before dropping another $800 I figured I would spend a little less to have them look for some bad grounds near the pulley. Ultimately the car ran fine on its current tune up until the point of the pulley swap. I know tunes can sometimes cause this but how is it possible that it works flawlessly for a few months and suddenly becomes a problem?
I do have an aftermarket stereo, sub, etc. Dont believe I have any of those wires near the pedal though. Im not against ripping it out though
Old Feb 15, 2016 | 06:51 PM
  #79
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Can you send me a copy of the tune?
I can at least give it a look over from a fresh set of eyes
Old Feb 15, 2016 | 10:19 PM
  #80
Spoolin8's Avatar
Spoolin8
Sounds good to me. Ill call the shop tomorrow but they have other cars in line before mine so im not sure when I can get a hold of it. He may still have it on the computer to email me though.
