Throttle Position Sensor maybe gone bad?
Old Jan 22, 2016 | 09:43 PM
chpmnsws6's Avatar
chpmnsws6
You can also pressure test the intake by putting a pvc cap with a rubber hose on your throttle body. Put a air tool fitting on it and turn your compressor down to 10 pounds or so. It doesn't take much to hear a massive leak. You can then spray soapy water on it like you do when looking for a tire leak.
Old Jan 30, 2016 | 02:11 PM
bruttix's Avatar
bruttix
Replaced the harmonic balancer, and serpentine belt. Come and go high pitch tune is completely gone!
Old Jan 30, 2016 | 03:50 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Yes, but how is 2K jump in rpms?
Old Jan 30, 2016 | 03:54 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Vacuum leak won't cause this, I know from experience. Plus a vacuum leak will set a P0420/430 code.
I suspect the throttle body is bad as well. It does happen. Sometimes it is an accelerator pedal problem.
Can you run the codes and report up? Not all codes will set a CEL (though the throttle body ones certainly will).
Possible it is the Maf as well, it won't hurt to clean the maf with maf cleaner, but be gentle as these are delicate devices. Any chance the maf isn't installed properly or the wires are loose? Along those lines, look at all the wiring at the maf and throttle body and ensure everything is plugged in well. You might also remove the negative battery cable for a few minutes to "reboot" the car. I've had to do that a couple of times.
