2005 C6 - C5 Diff Swap
Old Jan 20, 2016 | 03:28 PM
TX DSOM's Avatar
TX DSOM
Default 2005 C6 - C5 Diff Swap
I'm looking for information on the bracket needed to do the C5/C6 diff swap in the 2005's. There's quite a number of threads on the this subject, but it seems pictures are missing on all the good ones.
I remember running across a post on someone making a bolt in type bracket, but of coarse now I can't find it.
Does anyone have any information on this bracket? Any vendors sell this bracket???
Old Jan 20, 2016 | 07:51 PM
RicK T's Avatar
RicK T
No one sells it AFAIK but I could be wrong.
The original Sparo and Stanger383 stuff seems to be lost forever unfortunately.
Here are a couple different ones, one from Spinmonster:
https://www.corvetteforum.com/forums...into-05-a.html
https://www.corvetteforum.com/forums...-was-done.html
Old Jan 20, 2016 | 08:22 PM
TX DSOM's Avatar
TX DSOM
That's the bolt up type bracket I saw, Stanger383's bracket. (first link you posted)
I guess I'll see if he's still around and if he's still making them.
Old Jan 20, 2016 | 08:43 PM
shawnaj7731's Avatar
shawnaj7731
Default bracket.
i just did this conversion 3 months ago. I got the bracket from stanger383 but i had some serious vibration so i end up usings a c3 trans bracket and its a very simple design i will take some pictures this weekend . I end up making my own bracket with a c3 trans and it eliminated all noise and vibration.
Old Jan 20, 2016 | 08:58 PM
RicK T's Avatar
RicK T
That's what Spinmonster did in the link I posted above. Pics are in there.
Old Jan 20, 2016 | 09:03 PM
TX DSOM's Avatar
TX DSOM
Did you end up having to weld anything?
Spinmonster's bracket looks a little more fab than i want.
shawnaj7731
yup you got it bud i think that is all you need to make it work. Thanks Rick. you hit it right on the spot.
Old Jan 20, 2016 | 09:27 PM
TX DSOM's Avatar
TX DSOM
I'm trying to visualize how the mount secures to the cradle. Any specifics/pictures of that will be helpful.
Old Jan 21, 2016 | 09:24 PM
shawnaj7731
you have to weld a piece of metal or sandwich a piece so there is a flat surface to bolt to.
Old Feb 1, 2016 | 10:07 PM
bee-otch's Avatar
bee-otch
Cruising
I saw some say that they had to trim the cooling fins on the bottom of the c5 diff and others say it was a bolt in job once you had a bracket. Did you have to trim or grind anything on your c5 diff?
Old Oct 4, 2016 | 10:29 AM
JackLS1R1's Avatar
JackLS1R1
Any updates to this? I would love to put a C5 3.42 rear in my 2005
Old Oct 4, 2016 | 02:27 PM
irok's Avatar
irok
Default another option
I put a new 08 ZO6 differential in my 05.you will need to have a 30 spline output shaft installed in your transmission and an adapter plate to bolt transmission to differential.both are available from RPM transmission.this is an option for parts that are no longer available and may be of help to others
Old Oct 4, 2016 | 02:57 PM
JackLS1R1's Avatar
JackLS1R1
We are talking C5 swap in this thread. No mentions of C6 Z06 - Stay on target!
Old Oct 8, 2016 | 12:30 AM
chriswood's Avatar
chriswood
I bought a bracket to do this swap almost 2 years ago and I think its still in my garage. PM me if you are interested and ill send some pics.
Old Apr 2, 2022 | 08:55 PM
corvettevette's Avatar
corvettevette
3rd Gear
Default Do you have any more left?
hello do you have anymore left?
Old Apr 3, 2022 | 08:04 AM
helga203's Avatar
helga203
I think u need to look elsewhere.
Old Apr 3, 2022 | 05:08 PM
grinder11's Avatar
grinder11
I agree. 6 year old post, and crickets since 2018!!
Old Apr 4, 2022 | 08:42 AM
helga203's Avatar
helga203
u might be waiting a long time for an answer.
To 2005 C6 - C5 Diff Swap
