Lifter going out ?
Old Feb 29, 2016 | 01:49 PM
walleyejack's Avatar
walleyejack
Default Lifter going out ?
just asking, not sure what to make of this yet, drove my ls3 on a little cruise yesterday, cpl of us stopped by to visit a buddy, car is running great, start it up, and driver down the street and make my turn onto another street and yikes, a loud ticking can be heard with windows up and radio on, stop, listen and very loud, shut it off, check oil, nose around, all seems ok, start it up, and all quiet again, cept for the usual ticking, get home, stop off at a store, start moving again and it comes back, this time i keep driveing to the house, and it disappears. never heard it anymore for the day. is this possibly a lifter on its way out ? not sure what to think. recently put a cam, springs and pushrods in, not sure if one of them is the culprit, but it comes and goes, is what gets me.
any ideas would be welcome.
tia Al
Old Feb 29, 2016 | 03:37 PM
GS_DAN's Avatar
GS_DAN
In case it is a lifter, stop driving the car. Does the ticking go up with revs? When i lost a lifter you could hear the ticking increase with RPM. You could take the valve covers off and check the valve springs pretty easily.
If you dont hear it again, i would imagine the lifters are fine.
good luck
Old Feb 29, 2016 | 04:37 PM
walleyejack
good luck
yes, it increases with rpms. taking the covers off tonight and checking and retorquing rocker bolts, and check springs, and then run it to see if everything looks in line, but it is intermittent, it comes and goes, not contstant, that is the puzzle
Old Feb 29, 2016 | 06:14 PM
WW7's Avatar
WW7
It could be as simple as a piece of dirt got stuck in the oil hole in the lifter, or as serious as a lifter going bad...I did have an LS lifter go bad in a 383 motor in my 89 Corvette a few years ago.. When I started checking around I found there were quite a few that had problems with the LS lifters, so I installed a set of Cranes and had no more problems...WW
Old Feb 29, 2016 | 06:37 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Could be a rocker arm, could be a valve spring, or could be a lifter. While it is not a normal thing, it would not be the first time we have seen a stock lifter start to turn in the block and cut into the cam.
Try and not drive it to much. Get it home, pull the covers and see if any of the rockers are loose when the valve is closed. This would mean the cam or lifter has been damaged causing lash. Then I would pull the oil filter off and cut it apart and check for metal debris. If something is going bad, try not to drive it to much and hope to save the bearings in the engine before it scatters metal all through it.
Old Feb 29, 2016 | 08:45 PM
walleyejack
thank you sir. is parked in my garage, waiting for me to start checking things out. may be a trick to turn it over to close the valves, but will get it done.
thank you.
Old Feb 29, 2016 | 08:53 PM
5knives's Avatar
5knives
Happened to me but mine were not stock and I didn't have a loud tapping sound. Mine sounded more like an exhaust leak. After ruling that out, along with a bad injector, plug, etc., I had a shop do a more in-depth diagnosis. The lifter was slammed against the cam and continuously eating away at it. Lots of metal shavings throughout the engine. I'm in the final tuning stage of my rebuild.
Old Feb 29, 2016 | 08:58 PM
walleyejack
that is all bad, sorry to hear that.
Old Feb 29, 2016 | 09:04 PM
5knives's Avatar
5knives
Thanks. In hindsight I should have stopped driving it immediately but I was trying to diagnose it with each potential "fix". Mine did not sound like a bad lifter at all so I tried everything I thought it could be before going to a professional. Fingers crossed yours is nowhere near as bad as mine was.
Old Mar 1, 2016 | 10:40 AM
walleyejack
no broken springs, no lose rockers.
have to fire it up tonight and see if it will make "the clacking" sound.
Old Mar 1, 2016 | 08:02 PM
walleyejack
nothing abnormal.
Old Mar 1, 2016 | 08:47 PM
5knives's Avatar
5knives
Pull your plugs on the side you think the noise is coming from. See if they're wet with any oil/fuel build up.
After that, I'd have a leakdown and compression check done.
Old Mar 2, 2016 | 08:46 AM
SPIN20's Avatar
SPIN20
See if you can determine if it's coming from the front of the motor. I had a tapping sound and thought it was a lifter, replaced all of them and it turned out the my stock cam gear bolts backed out and were hitting the timing cover. The engine had 20k miles on it and was bone stock when it happened. Thankfully I caught it before any damage occurred to the engine. I'm not sure if you have the 1 or 3 bolt cam gear though. Mine was the 3 bolt.
Old Mar 2, 2016 | 09:29 AM
walleyejack
thanks, mine is 3 bolt, new everything in the front. fired it last night several times, didn t make the ticking/clacking. Martin Smallwood says "
It is not out of the ordinary for a stock lifter to bleed down and not be able to pump up quickly enough when the valve goes to open. This can cause a ticking sound especially at lower RPM's where oil pressure is lower." i guess this is possible. i bumped the oil from 5 / 30 to 0 / 40 when i changed everything up, may be a slight problem, but i highly doubt it.
thank you.
To Lifter going out ?
