Replacing torque tube
Old Apr 5, 2016 | 09:43 AM
qpridge's Avatar
qpridge
Navigator
Default Replacing torque tube
I noticed a rattling noise coming from under my car and went by a transmission shop. Once they drove it, I was told that it was my torque tube and the bearings were going out. Was just wondering if anyone has replaced a torque tube and could offer my any suggestions on what to do or who to get to fix it. I have a 2009 Corvette base model.
Old Apr 5, 2016 | 09:58 AM
da6speed's Avatar
da6speed
I pulled mine out and rebuilt it when I was swapping new trans and converter. If you do a search, there's a few threads on this subject that will give ya info you need. IIRC, it's two bushings and three bearings is all that's needed. I ordered my bearings offline and the bushings from a German bmw motorsports website, as they are supposed to be better than what's available at parts house.
Old Apr 5, 2016 | 10:12 AM
qpridge's Avatar
qpridge
Navigator
Okay, thanks for that information. I may see if someone could possibly help me repair it. I wasn't sure if a dealership could repair it at a "reasonable rate".
Old Apr 5, 2016 | 11:04 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You can replace the bearings instead of the whole tube. They're ~$150
If it's an M6 I'd consider replacing the pilot bearing and maybe even clutch slave cylinder while it's apart.
Old Apr 5, 2016 | 12:11 PM
qpridge's Avatar
qpridge
Navigator
That sounds a lot better than the $2000 plus quote that I've gotten. I believe I will request that he bearings be replaced instead of the whole tube. Thanks for that info!
Old Apr 5, 2016 | 12:26 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Keep in mind dealerships won't service them, they will only replace the whole thing. They aren't bad to take apart and here are the bearings you need:
x2
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
x1
Old Apr 5, 2016 | 12:59 PM
qpridge's Avatar
qpridge
Navigator
The bearings are not that bad as far as pricing goes. Is the tube hard to remove?
Old Apr 5, 2016 | 01:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It's not much fun. Have to remove transmission/rear basically
Old Apr 5, 2016 | 03:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! Been there done that!!
Here is what you will be dealing with. This is an early C5 TT but, similar to yours inside:
- C5 TORQUE TUBE/COUPLERS Repairs: https://www.corvetteforum.com/forums...with-pics.html
Depending on you SKILLs and or desire to save cash, its a rather involved repair. Its doable and not all that COMPLEX.
I agree, the STEALERSHIP will only install a new TT and will not repair the old one.
The entire drivetrain will be out so, you might consider other drive train maintenance items that should be addressed especially if you have a MN6 Car.
One will be differential output shaft seal replacement.
Again, its a C5 post but pretty much the same seals:
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Old Apr 7, 2016 | 02:06 AM
Gering's Avatar
Gering
Tolero Apto Victum
Sorry to hear that OP, here are some pics of my TT and bearing, the Vet was around 207K miles as an 07 DD.
Good luck with your repairs.
Old Apr 7, 2016 | 08:15 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Just a small scratch.
That's a destroyed coupler
Old Apr 8, 2016 | 09:51 PM
thehaggis's Avatar
thehaggis
What were the symptoms for the couplers going bad?
Old Apr 8, 2016 | 11:13 PM
Gering's Avatar
Gering
Tolero Apto Victum
For me, when I went above 3500 rpm I could feel a heavy vibration coming from the right rear, it felt like my diff was damaged.
Old Nov 27, 2017 | 07:50 PM
emclass's Avatar
emclass
I second that, whining sound from driver rear wheel well area. Thought it was wheel bearing or differential, turns out to be torque tube. Under extended warranty from GM, for replacement.
Old Nov 27, 2017 | 11:11 PM
ffemt702's Avatar
ffemt702
3rd Gear
mine is a c7 7sp and my torque bearing went out. Chevy dealer recommends clutch assy change due to hot spots on flywheel. Can a bad bearing in the torque tube cause the clutch to wobble and cause hot spots on flywheel?
Old Nov 28, 2017 | 12:03 AM
Dano523's Avatar
Dano523
Yes, but unless you can show blame to one warranty part going bad and directly taking out a non warranty part alone (clutch), it's a hard battle to get GM to pay replace a non warranty part.
Either way, if the drive train is out, and the clutch has problems, then have them replace the entire clutch system now (even if they are going to charge you parts). It will save you about $2K of labor if they have to pull the drive train back out on your dime to replace it sooner, than later instead.
Truth is, I would work the deal with them that since the TT went bad and it caused problems with the clutch, you will eat the clutch parts cost to change all the clutch parts out now if they will not replace them under warrenty, but they have to eat the labor replacing the clutch system isntead.
Old Nov 27, 2018 | 10:16 PM
Thump Y's Avatar
Thump Y
x2
x1
are these bearings for c6 auto or manual?
To Replacing torque tube
Old Nov 28, 2018 | 12:14 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
after 6 months being worked on, i am now getting what sounds like to me gear whine from the bell housing area. am i a candidate for a torque tube rebuild?
Old Nov 28, 2018 | 10:33 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
My post for bearing sizes was for manual transmissions... no idea if the torque tube bearings are different for autos. Call someone like RPM and ask
Old Nov 29, 2018 | 12:04 AM
Cherokee Nation's Avatar
Cherokee Nation
I read today 11/28/18 that the manual and autos used the same parts on the driveshaft.
