code po 496
Old May 9, 2016 | 10:01 PM
walleyejack's Avatar
walleyejack
Default code po 496
c6 ls3, code popped up yesterday, Evaporative Emission System High Purge Flow, not sure what it means or how to fix it. i googled it and some of the older vehicles said charcoal in the canister was a problem, over filling at the gas station, which i don t do, when it shuts off, i m done. any ideas would be appreciated.
tia Al
Old May 9, 2016 | 10:16 PM
RicK T's Avatar
RicK T
Not a very common issue, but here is one I found for the purge valve solenoid on the front of the passenger side valve cover:
https://www.corvetteforum.com/forums...-solenoid.html
Old May 9, 2016 | 10:24 PM
walleyejack
thank you.. i searched, but, didn t put it in like the post.
i will nose around it tomorrow.
Old May 10, 2016 | 03:42 PM
walleyejack
any chance it may correct itself over a bit of time and driving ?
from what i can find, it is not going to hurt it to drive a bit.
how does one define if it is the Solenoid on the engine, or the vent under the rear, that is the culprit ?
Old May 10, 2016 | 07:19 PM
Dano523's Avatar
Dano523
DTC Descriptor
DTC P0496: Evaporative Emission System Flow During Non-Purge
Circuit/System Testing
Start the engine.
Seal the EVAP system using the Purge/Seal function with a scan tool.
Observe the FTP sensor with a scan tool. The Fuel Tank Pressure Sensor parameter should be less than 1.7 volts after 90 seconds.
⇒ If the Fuel Tank Pressure Sensor parameter is greater than the specified range, replace the EVAP canister purge solenoid valve.
Repair,
http://www.mediafire.com/download/de...496_repair.pdf
And its a cheap enough part, so just replace it if you still have problems after popping the connectors off to clean and re-attach them and the problem does not go away!!!!!
Its the valve that the Orange connector is plugged into.
As for getting to it, remove the oil filler cap, pull straight up on the fuel rail cover to remove it from the motor, and it right there at the front of the valve cover. When you put the fuel rail cover back on, put some dielectric grease on the rubber grommets on it bottom, and it will make installing and remove the fuel rail cover again much easier.
Old May 11, 2016 | 08:46 AM
walleyejack
Originally Posted by Dano523
DTC Descriptor
Start the engine.
Repair,
thank you, i think i will just replace it, i don t have the testing equipment, but from what i read, this has to be the problem. i disconnected and checked all the connections, and gas cap, to no avial. will change it tonight. never heard or read of any C6 s having this problem.. thanks for the tip on the DE grease, good idea.
Al
Old May 11, 2016 | 06:05 PM
Dano523's Avatar
Dano523
No worries, but do clean the connectors and reconnect them with testing to just weed these out at the problem isntead. Hence the solenoid may be fine, and some how you have a bad connection, ground or cracked wire instead.
Old May 11, 2016 | 06:49 PM
walleyejack
Right on. got it on and no check engine,, whooohhooo
thank you everyone for your input
Al
Old May 13, 2016 | 09:40 PM
walleyejack
well, the light came back on after 2 days, will have to check on the valve under the back fender. thought i had it beat wahaaaa
Old May 14, 2016 | 10:31 AM
walleyejack
Now that I replace the one on the engine is it safe to say I replace the one in the back under the fender that it will be good to go? I don't know of any other options right now ?
Old May 14, 2016 | 07:31 PM
walleyejack
Stealership says could be the canister or could be the vent in the back, vent is $23 and the bloody harness is $42. crazy, i need to talk to the shop wizard before i replace anything else needlessly.
Old May 15, 2016 | 11:11 AM
irok's Avatar
irok
Default dirt cheap
For peanuts change the $23. rear vent .most don't need the harness replaced
Old May 15, 2016 | 11:36 AM
walleyejack
The dealer told me that when you replace vent the harness doesn't hook up to it I need the replacement harness adapter harness. Just what i was told. 23 bucks is nothing. The BS 4" harness adaptor tho. GM has to make money somehow.
I was looking for the valve yesterday, jacked up, wheels off, couldn t see it. But, i am old, so ...
Old May 15, 2016 | 05:30 PM
irok's Avatar
irok
I believe the plug on the harness has changed in later years and some cars have needed it and some haven't.you need to look for the vent on passenger side of car.its a simple replacement even for us guys that are getting older
Old May 15, 2016 | 05:44 PM
walleyejack
I understand os on left side. But buried up in tjere somewhere ?
Old May 15, 2016 | 06:01 PM
RicK T's Avatar
RicK T
Passenger side.
Here's a DIY with pics:
https://www.corvetteforum.com/forums...49-w-pics.html
Old May 15, 2016 | 06:49 PM
walleyejack
Passenger side.
Ok thank you. Left side has always been the drivers side, but, after 60 yrs things change i guess. Thanks again Rick.
To code po 496
Old May 15, 2016 | 06:54 PM
walleyejack
Nice right up on replacement 3 Tick T
Old May 17, 2016 | 10:52 AM
walleyejack
just an update, took it in to the dealer he did some more tests, and is nothing to do with vent or solenoid really, says there is a constant ground, and makes it pull too much vacuum, and tricks the ecm, so either a wire melted somewhere or something in the ecm that the tuner missed in Janurary, but i can t see that, because it is only happening now, and been driving it, so must be a wire, he is going to spend a bit of time on it to see what he can find out.
Old May 17, 2016 | 02:54 PM
walleyejack
tech says, is in the tune or bad ECM, all wiring checked out. constant ground, is in ecm
