Ls3 map?????
Old Jun 11, 2016 | 12:21 PM
CMY SIX's Avatar
CMY SIX
Default Ls3 map?????
is the LS3 map better then the LS2? does it make any sense to swap a LS3 map sensor and harness on to a NA LS2?
Old Jun 11, 2016 | 12:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Nope
Old Jun 11, 2016 | 07:27 PM
Dano523's Avatar
Dano523
Ditto, and the only reason to swap out the manifold absolute pressure sensor is if you are going super charged, and need a 2 or 3 bar MAP sensor instead (depending on the amount of boost).
Hence 1 Bar = 14.5037738 Psi,
So when you are super charging, you need a sensor that is able to not only able to read the atmospheric pressure (14.7psi at sea level) going into the intake manifold, but the added super charger pressure as well.
Old Jun 11, 2016 | 07:35 PM
CMY SIX's Avatar
CMY SIX
thank you!
To Ls3 map?????
