use the search button then come back with some specific Q's depending on the cam and the miles on the car and the amount of work to get there, do you want to do? timing chain and sprockets, valve springs seal rocker arms, HB if a high lift cam you will do springs, single bee hive, dual coil. so you see we just can't tell you what you want
Where are you located, what fuel is available, a good speed shop in your area is where I would start looking, even if you want to do the work yourself.
Emissions may also come to play depending on where you are located.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by Angel_LSX
Thanks guys. I'm looking for 4500 rpm -6000rpm power.
So far I have
Fast 102 Manifold
Intake
I'm looking unit heads & cam. Just want to make sure I'm going to right direction.
Drivability isn't too much of a concern.
As long as it doesn't turn off at red lights I'll be happy with it .
Looking to do just a bolt ons set up with a 100shot
My car has 90k miles .
Thanks guys for the time and response. !
Headers? I'm going to assume so.
If you are wanting top end power and friendly a shot the G6X3 might be something to look into. It is a big cam but some of the fastest cars are running that setup.
