Sometimes my driver seat does not go to the correct position when I get in the car. It goes about half way horizontal. If I move it a little bit and then press the button it goes where it is supposed to.
I was thinking that the sensor might be dirty.
Where is it?
There have been posts before, but no answers.
You could have one of a few problems. Your seat module could be failing, the sensor could be bad, the plug may be catching on the carpet, or you may just need to re-index your seat.
To re-index you run the seat to the max of all positions with the ignition on. Then shut the car off and check to see if the seat goes where it should.
I have no idea how to diag a seat module.
Here is where the pos. sensor is located. It is #34 in this diagram.
Where is it?
2008 Z06 LZ3
My base model does exactly the same thing, and with low mileage...
