Auto meter /Dash logic
Old Sep 6, 2016 | 05:03 PM
Rusty-'s Avatar
Rusty-
Default Auto meter /Dash logic
Just got the dash logic unit today and i am a bit confused about the boost portion of it it shows -12 at idle and it does not seem to go to a positive under boost conditions. This was one of the main reasons for this purchase i liked the factory look with out all the pod's. Any insight would be helpful
Old Sep 6, 2016 | 06:55 PM
Unreal's Avatar
Unreal
Do you have a map sensor capable of reading boost? If not that is the problem. It only shows what the stock ecu sees. If your tuner didn't properly calibrate the car to know boost, it can't tell you
Old Sep 6, 2016 | 07:05 PM
Mike's LS3's Avatar
Mike's LS3
with Unreal.
A non boosted car from the factory will need a different MAP sensor to read boost. Swap in a ZR1 MAP sensor.
Then make sure your tune recognizes those changes. It's a matter of changing two values in the tune.
Old Sep 6, 2016 | 07:40 PM
Unreal's Avatar
Unreal
And I'm afraid to ask, but you do a have a blower or turbo correct? Car will never see boost without a power adder to create boost.
Old Sep 6, 2016 | 08:31 PM
Rusty-'s Avatar
Rusty-
What's a blower? (haha) i just had an a&a v3 installed 1 7/8 Kooks headers, cat delete, x pipe and a full dyne tune. maybe its in backwards lol
Old Sep 6, 2016 | 08:35 PM
Rusty-'s Avatar
Rusty-
you
Not sure the shop did not mention any map sensor swap nor did i see it on the bill. If this is the case i could be very costly to have it re tuned
Old Sep 6, 2016 | 11:23 PM
Mike's LS3's Avatar
Mike's LS3
The MAP sensor swap takes 3 min. Your tuner just needs to make two value changes and flash. No dyno pulls or driving necessary. They should not charge you for 5 min. job.
Old Sep 6, 2016 | 11:30 PM
Unreal's Avatar
Unreal
No retuning required, just plug in 2 values. If they charge you to do that, they are not a shop you want to deal with. They should gladly help a customer out that paid that much already with <2 minutes of their time.
Old Sep 7, 2016 | 03:16 PM
Rusty-'s Avatar
Rusty-
Well gave the shop a call and they said they could sneak it in on Friday. I asked if there was a charge and for the tuning no but about 75.00 for the Map sensor.......Sound about right ??
Old Sep 7, 2016 | 03:32 PM
jft69z's Avatar
jft69z
Nope...Even GM list price is only $44.07
http://www.wholesalegmpartsonline.co.../12592525.html
http://www.wholesalegmpartsonline.co...ssembly=404895
https://www.google.com/search?q=1259...xtMenu&ie=&oe=
Old Sep 7, 2016 | 03:43 PM
Rusty-'s Avatar
Rusty-
Price may be off not sure but the part you listed may not be the part i need Im running a A&A v3 supercharger not the roots type
Old Sep 7, 2016 | 03:44 PM
jft69z's Avatar
jft69z
It's a ZR1 sensor in the links. (CTS-V & ZL1 too). Where is the MAP sensor on your car now & does it look similar to the OEM ZR1 sensor?
Old Sep 7, 2016 | 05:42 PM
Rusty-'s Avatar
Rusty-
You are 100% correct i just checked and it is at the left front of the intake.
So i can see the massive inflation on a part that takes 1min to install. trying to see if i can prime one before my appointment :thumbs
Old Sep 7, 2016 | 08:16 PM
jft69z's Avatar
jft69z
Check here, it may be helpful for the 2 numbers you have to change. Post # 9 has the stock ZR1 numbers listed for that MAP sensor. (same numbers listed under my tune as well).
http://www.hptuners.com/forum/showth...l=1#post279068
With the new version of HPTuners it will be listed under Engine--Airflow.
Old Sep 8, 2016 | 01:22 PM
Brandon619's Avatar
Brandon619
Good info here.
Old Sep 9, 2016 | 09:02 PM
Rusty-'s Avatar
Rusty-
Map sensor has been installed and everything is working as it should.
Thanks for the help
Old Sep 9, 2016 | 10:47 PM
Mike's LS3's Avatar
Mike's LS3
Thanks for the help
Old Jul 1, 2020 | 07:58 PM
03hdfatboy's Avatar
03hdfatboy
quick question the PID for HP is (30004) but doesn't work always shows 0
also shows more than one PID for TQ (30005) dosent work but (1016) does.
what am i doing wrong?
To Auto meter /Dash logic
